  2. Mixed-Signal Design
  3. simvision analog variables and signals display issue
  • Subscribers 67
  • Views 2992
mxgong
mxgong 7 months ago
I am running ams simulation in the interactive mode.
However, the simulation has gone through, but I can only observe the digital signals. All analog signals (including inputs and outputs) and variables within the analog begin block are showing no value in the waveform window.
Here vin[8] is a net in the testbench schematic. triggers_out[x] are digital signals. Ceq is a real number inside the analog begin block.
When I stop the simulation and open result browser, the signals in schematics are saved there.
Minxiang
    Andrew Beckett 7 months ago
    Minxiang,
    Which XCELIUM and SPECTRE sub-versions are you using? (these will be reported in the simulation log)
  • mxgong
    mxgong 7 months ago in reply to Andrew Beckett
    Thanks for the quick reply.
    the XCELIUM version is 23.03-a071 64b
    the spectre version is 24.1.0.314.isr6 64b
    Minxiang
  • mxgong
    mxgong 7 months ago
    If I change data format of spectre from udb to sst2. It works. I know simvision uses sst2 format, but I take a look in udb option that it did save the data in sst2. I have to manually reload database in simvision. Any root cause of this?
    Andrew Beckett 7 months ago in reply to mxgong
    Can you try with a more recent version of both XCELIUM and Spectre? There were some UDB-related issues with waveform display (without knowing the precise details it's hard for me to check what broke when and was fixed when).
  • mxgong
    The previous one that worked with udb is using XCELIUM 64b 20.09-s009 and Spectre 64b 21.1.0.648.
    Minxiang
    This worked before, then something broke, and as far as I know it's been fixed in the meantime. Hence my suggestion to use a later version (I'm just not sure whether it's on the XCELIUM or SPECTRE side - I would have to do some digging for that and I'm away from work for a few days...)
