  2. RF Design
  3. Noise aware PLL design flow
  • Subscribers 63
  • Views 17214
sriram123
sriram123 over 16 years ago
Hi, I use a collpitts topology for my VCO. While attempting to extract the model of the VCO, I can't give any VSS to my circuit because of this topology. So I get an error when I run PSS/PNOISE. I guess the PLL design flow was designed for LC-VCOs. Is there any work around for the problem? Thanks Sriram
    Sriram,
    What was the precise error? A few pictures might help. I don't thing there's any reason why you can't use a Collpitts oscillator with this flow. You probably need to have the vco_vss source on your testbench, and to create a Vss pin on your "DUT", even if it is not used.
  • sriram123
    In the collpitts topology, there is no room for a VCO drive or VSS. So conceptually I can't place VSS probe in the testbench which gives me an error. On the other hand, in LC VCO topology, you need to give a tail current or drive to the VCO due to which you have VSS. Can I just connect the ground node to VSS in this case?
    You can still have it in the testbench but not connected to anything. That's what I was suggesting. You also didn't post the error as I requested. As I said before, pictures would help.
  • sriram123
    Thanks I did as you told and connected VSS to noconnection. The PSS runs for a long time and then returns me this error. I have attached the screenshot. Please help Sriram
  • Tawna
    Tawna over 16 years ago
     Hir Sriram,
    The error message gave an important clue...you ran out of memory.  Please type in an xterm
    spectre -h rfmemory
     like it suggests in the error message.  There are a list of suggestions for you to go through.  If you continue to have difficulty, I suggest contacting Cadence Customer Support.
    best regards,
    Tawna
