  2. RF Design
  3. DC Operating Points not displayed on Schematic Diagram ...
  • Subscribers 64
  • Views 16376
DC Operating Points not displayed on Schematic Diagram (ADE 5.10; USR 6.127)
StillLearning
StillLearning over 13 years ago
All,
I have recently installed a new Model Library, and am unable to see the DC Operating Points on the schematic diagram after clicking on Results->Annotate->DC Operating Points in Virtuoso ADE. I am using ADE 5.10 and USR6.127.
I wonder if anyone has any suggestion on how to resolve this issue.
Thank you.
    This is likely to be related to the design kit  you're using - perhaps you can state which design kit, and which version of that design kit you're using - maybe there's somebody on the forum who is familiar with it and can advise?
  • StillLearning
    Hello Andrew,
    Thank you for your prompt attention and the remark. I also was under the impression that the issue was design-kit-related; however, one of my colleagues is using the same design kit, and he is able to view the DC Operating Points.
    Nevertheless, I am using Revision 1.0 of the BCS180G design kit by HHNEC (http://www.hhnec.com).
    Given the above, I wonder if there is any setup that I need to do in Virtuoso ADE, CIW, or elsewhere to resolve the issue. Please advise.
    Thank you.
  • StillLearning
    Andrew,
    Updated information:  when I use Results->Print->DC Operating Points in the Virtuoso ADE, I can see the DC Operating Points in the "Results Display Window;" as such, it appears that the issue is not design-kit-related, as the data exist but are not displayed on the schematic diagram.
    I hope this helps identify the cause of the issue.
    Thank you.
  • ECILCadence
    ECILCadence over 9 years ago
    Pls check your model files..these may be hspice model. we also faced the similar problems when using hspice models but resolved it by using spectre model files.
    regards
