  2. RF Design
  3. How to avoid Hidden State in VerilogA model for Spectre...
  • Replies 12
  • Subscribers 66
  • Views 31344
How to avoid Hidden State in VerilogA model for SpectreRF
RFStuff
RFStuff over 13 years ago
 Dear All,
I am a beginner in verilogA .
I wrote a code but when I ran PSS it showed hidden state in the code and didn't run.
My behavioural model is as below:-
// VerilogA for VERILOG_A_MODEL, HARD_LIMIT_GM, veriloga
`include "constants.vams"
`include "disciplines.vams"
module HARD_LIMIT_GM(in,out);
  inout in,out;
  parameter real vtrans = 0;
  parameter real tdelay = 0 from [0:inf);
  parameter real trise = 1p from (0:inf);
  parameter real tfall = 1p from (0:inf);
  parameter real Gm=-5m;
  electrical in,out;
  real vout_val;
  analog begin
         @ (cross(V(in) - vtrans, 1))  vout_val = 1;
         @ (cross(V(in) - vtrans, -1)) vout_val = 0;
         I(out) <+ Gm * transition( vout_val, tdelay, trise, tfall);
  end
endmodule
Could anybody please tell how I can avoid the hidden state  (vout_val ) ?
Kind Regards,
  • seadoftj
    seadoftj over 9 years ago
     I will like to know while this Normalised LMS algorithm could not be supported in PSS analysis due to the hidden state variable "WtsReg".
    Can you please help proffer solution or suggestion to the code in verilogA.
    // VerilogA for IM2_Cancellation, LMS, veriloga
    module LMS(clk,Inp_Sig,Error, Wts);
    input clk, Error,Inp_Sig;
    electrical clk, Error,Inp_Sig;
    output Wts;
    electrical Wts;
    parameter real mu=0.2 ; //varies between 0 to 2
    integer  vth;
    integer Clk;
    real ErrorReg;
    real WtsReg;
    integer Vin;
    real Quot;
    analog begin
            Clk = (V(clk)> 0.5)? 1:0;
            @(initial_step)
            begin
                    WtsReg = 0;
                    V(Wts) <+ 0;
            end
            if (V(Inp_Sig)) begin
                    ErrorReg =  V(Error);
                    V(Wts) <+ WtsReg;
            end
            @ (cross(Clk - 0.5, +1)) // rising edge of clock signal
            begin
                    Quot = V(Inp_Sig)/(V(Inp_Sig)*V(Inp_Sig));
                    WtsReg = WtsReg + mu * ErrorReg * Quot;
            end
    end
    endmodule
    Did you read the http://www.designers-guide.org/Analysis/hidden-state.pdf paper I pointed at earlier in this thread? The problem is that you are relying on sampling the signal at the clock edge into the variable WtsReg which is then a hidden state variable. You need to employ one of the strategies discussed in that paper so that this state is represented as an electrical node rather than a variable; variables have to be updated on every iteration.
    It's also not a good idea to have the contribution statement (the V(Wts)<+WtsReg;) inside a conditional statement - in fact I'm not sure that's really doing anything useful (so remove the surrounding if() statement).
    This thread seems to have become a bit of a dumping ground for questions on hidden state; the forum guidelines ask forum users not to post on the end of old threads to avoid muddying the answers and making it harder for people to find specific answers to specific questions.
    Kind Regards,
