  2. RF Design
  3. output resistance test vs I_out(Vout) test
  • Replies 8
  • Subscribers 63
  • Views 8257
robert 21
robert 21 over 6 years ago
Hello for a basic current mirror when we do an output current  characteristics then we  sweep test voltage source and measure mos drain current.
To calculate the incremental output resistance i saw  a remark that we need 1V DC bias to put into into Vdc source and Ac magnitude to make 1u.
I have three question for this situation:
1.what is the effect of connecting Voltage source in series with current source?
the current source will force a certain current , and the voltage source will force a voltage on the end of the current source?
2.when we are testing output current we put on the output DC voltage source and sweeping it measuring the current.
how adding another  test voltage source not interfering with the behavior of the circuit?
is there more passive way to measure the voltage and current on the output?
3.when measuring output resistance(output impedance) do we need to put 1V bias voltage in the Vdc source beyong the Vac 1uV amplitude?
or we could test impedance with AC magnitude only?
    ShawnLogan over 6 years ago
    Dear robert21,
    Please consider what an ideal current source (defined as having an infinite output impedance) does. Its funciton is to set a DC current independent of what the voltages are its terminals. Hence, if you are trying to establish a voltage at the drain of the current source device, placing an ideal voltage source of any value at the positive terminal of the current source in your schematic will not impact the DC current of the ideal current source.
    I think I outlined a method to do this in a reply to your posted question at:
    community.cadence.com/.../test-signal-iprobe-rout-calculation
    You mentioned that the method appeared to work. Is there a reason you cannot use the same methodology in your current example?
    Yes. If you do not, you are not controlling the drain voltage of your nmos_lv_3 device. The output impedance of an MOS device is well known to be a function of its drain-source voltage.
    I hope these address your questions robert21,
    Shawn
  • robert 21
    robert 21 over 6 years ago in reply to ShawnLogan
    Hello Shawn, an Idial 10uA current source component  gives me a huge 1.4V drop. (as shown bellow)
    Why in simulation i have such a voltage drop on ideal current source?
    ShawnLogan over 6 years ago in reply to robert 21
    Dear robert21,
    Than
    The voltage drop  will always be vdd - vgs where vgs is the gate source voltage of your diode connected M0 device. As I think I mentioned in my last response robert21, an ideal current source will force the DC current and with an infinite output impedance can support any voltage at its terminals. Its lower potential terminal voltage is set by the gate-source voltage of your diode connected device M0 at a current of 10 uA. The upper terminal is set by whatever voltage you have assigned node vdd - in your example 1.8 V.
    Is my answer any clearer to you this time?
    Shawn
  • robert 21
    Hello Shawn why the voltage drop over the current source cant be zero,
    so we will see 1.8V an 10uA on the output of the idial current source?
    Thanks.
    Andrew Beckett over 6 years ago in reply to robert 21
    DIdn't Shawn just explain that? Why would it be zero? The voltage is defined by the diode-connected transistor with 10um flowing through it, not by a voltage set by the current source itself (since a current source does not set a voltage...). This is pretty basic electronics...
  • robert 21
    robert 21 over 6 years ago in reply to Andrew Beckett
    Hello Andrew, If i understand it correctly the output voltage cannot be 1.8V because the Drain voltage of the NMOS has to such that it supports 10uA going threw it
    so the voltage Source is irrelevant in this case?
    it will produce the voltage based on the current going threw it?
    correct?
    Dear robert21,
    Andrew is correct and your understanding is now correct too!
    As I think I noted, the current source, since it has an infinite output impedance, will force the 10 uA current independent of the voltage at its terminals. Hence, the DC voltage to which you set node vdd does not impact the DC voltage across the gate-source junction of your diode connected device M0.
    The MOS diode connected device M0 gate-source voltage is defined by its drain source current per the constitutive equations governing it.
    Shawn
  • robert 21
    Thank you very much
