  2. Allegro X APD
  3. Ultralibrarian doesn't work in searh providers
  • Subscribers 69
  • Views 7782
RyuHimura
RyuHimura over 6 years ago
Hi, I have a Cadence SP 17.4 and when I click on search providers and log in with my account, appear a pop-up window wit this message: ERROR (SPDWSRV-508): Unable to process this request for Ultra Librarian because of an internal error. Retry the operation.
Has anyone else seen this error.
  • steve
    steve over 6 years ago
    Give this a try community.cadence.com/.../search-providers-not-working
  • Hawk10
    Hawk10 over 6 years ago in reply to steve
    Dear sir.Need your help.
    I have custom made PCB and its .brd file.I don't have its schematic.I had validate schematic and interlinked successfully with .brd file. After ECO it do not change routing but unplaced parts.Is there any way to save placement.
    Thanks and regards,
  • steve
    steve over 6 years ago in reply to Hawk10
    Before you import the netlist changes try a File - Export - Placement, write the file out. Import the netlist then use File - Import - Placement (make sure add unplaced components is checked and also ensure that the origin you used in the export is the same on import. By default unless you have made major changes in the schematic parts shouldn't be unplaced but you say that you didn't have a schematic so if you have redrawn this there could be differences in the device name.
  • Hawk10
    steve
    Thanks a lot.It worked.
    No having some errors.(Routing).Seems i have to export cmg and then import to this placed version design. What do you says?
  • Hawk10
    @Steve
    I need your helponce again.
    I have costume made .brd file i have validate(Ref des-Net name same as in schematic) it and export its changes
    to board.It was linked properly.
    But it unroute nets and make it dummy nets and make a new rats net.
    Is there any solution to save routing.Or it can take same name as in schematic rather then dummy net.
    Is there any way that dummy nets do not pupup it take same name as assigned in schematic.
