  2. Allegro X Capture CIS
  3. prefprop.txt properties aren't working
  • Replies 12
  • Subscribers 50
  • Views 9914
Lock2002
Lock2002 over 5 years ago
Cadence 17.4
My ini location (according to the session log)
INI File Location:C:\Users\xxxxx\cdssetup\OrCAD_Capture/17.4.0/Capture.ini
in the .ini file
PrefPropPath=c:\users\xxxxx\cdssetup\orcad_capture\17.4.0\prefprop.txt
All of the properties are showing up in prefprop.txt, but none are showing up regardless of the drop down option (schematic nets or flat nets).
  • Lock2002
    0 Lock2002 over 5 years ago
    more info:
    The current schematic will not display the properties, but if I create a new one it will........
  • Lock2002
    0 Lock2002 over 5 years ago in reply to Lock2002
    it appears to be an issue with Capture Constraint Manager being enabled in the design. Is it possible to disable it?
    I can say for now I won't be missing Capture when we jump ship. It used to be a great tool....
  • excellon1
    0 excellon1 over 5 years ago in reply to Lock2002
    Hi Lock
    Over on the Cadence site there is an article on how to force Capture to read custom config file such as PrefProp. Possibly worth a look.
    About 1/2 way down the page.
    https://community.cadence.com/cadence_blogs_8/b/pcb/posts/follow-video-embedded-troubleshooting-articles-for-easier-debugging-and-empowered-learning
    What Schematic tool are you going to ?
    All the best.
  • Lock2002
    0 Lock2002 over 5 years ago in reply to excellon1
    schematic and layout. Mentor Expedition
  • Lock2002
    Thanks for the info, but it appears that once you've used Constraint Manager in Capture you're stuck with it. You can't add any net property constraints. I tried to do it manually. No-go
