  2. Allegro X Capture CIS
  3. prefprop.txt properties aren't working
  • Replies 12
  • Subscribers 50
  • Views 9915
Lock2002
Lock2002 over 5 years ago
Cadence 17.4
My ini location (according to the session log)
INI File Location:C:\Users\xxxxx\cdssetup\OrCAD_Capture/17.4.0/Capture.ini
in the .ini file
PrefPropPath=c:\users\xxxxx\cdssetup\orcad_capture\17.4.0\prefprop.txt
All of the properties are showing up in prefprop.txt, but none are showing up regardless of the drop down option (schematic nets or flat nets).
  • redwire
    0 redwire over 5 years ago in reply to Lock2002
    I just ran into this issue as well.  No way to edit/view the properties like I've always been able to do.  I am shocked as well at the decline of this tool and am shopping a replacement after 25yrs of declining innovation and horrendous tool changes forced on us....
  • steve
    0 steve over 5 years ago in reply to redwire
    So once you enable the CM flow you use CM launched from Capture to add Constraints (the same way you do in PCB Editor). Not sure what the issue with that is..........
  • steve
    0 steve over 5 years ago in reply to Lock2002
    Take a look at this Can I disable constraints flow from Allegro Design Entry CIS (OrCAD Capture CIS) to Allegro PCB Editor Netlist? (cadence.com) which may help.
  • Lock2002
    0 Lock2002 over 5 years ago in reply to steve
    I've seen that. Thanks. Short answer is once you've enable CM in Capture you can't go back, unless you want to use an older version of the schematic.
  • redwire
    0 redwire over 5 years ago in reply to steve
    It's a pretty big issue if you have a CM enabled OrCAD flow and you transfer the design to a license that does not include that.  You can't see/edit any of the properties on the nets that were once available before the CM flow got enabled.  That makes it impossible to manage the design on a lower license.
