  2. Allegro X Capture CIS
  3. prefprop.txt properties aren't working
  • Replies 12
  • Subscribers 50
  • Views 9921
Lock2002
Lock2002 over 5 years ago
Cadence 17.4
My ini location (according to the session log)
INI File Location:C:\Users\xxxxx\cdssetup\OrCAD_Capture/17.4.0/Capture.ini
in the .ini file
PrefPropPath=c:\users\xxxxx\cdssetup\orcad_capture\17.4.0\prefprop.txt
All of the properties are showing up in prefprop.txt, but none are showing up regardless of the drop down option (schematic nets or flat nets).
  • excellon1
    0 excellon1 over 5 years ago in reply to redwire
    Hi Red.
    That CM Flow got introduced in 17.2. Honestly I have never used it. I know for a fact that Major IC Mfr's that make PC Motherboards also do not use it. More curiosity than anything but what on earth is the advantage on having it in Capture.
    It kind of seems wierd to me that engineers or drafters would be setting critical net parameters on the schematic. Seems like it just adds to or can hamper the board creation in particular because if an engineer is unaware of the board topology aka stackup etc the bit twiddling at the schematic level is going to cause problems.
    I am probably missing something of value here, any clues as to why use it ?. I am kind of drawing a blank on this.
    Thanks.
  • jc teyssier
    0 jc teyssier over 5 years ago in reply to excellon1
    Same here: never use (and not planing to): parameters from schematic are only NET_PHYSICAL_TYPE NET_SPACING_TYPE NET_ELECTRICAL_TYPE and sometimes DIFF_PAIR in order to group things.
