  2. Allegro X Capture CIS
  3. ORCAP-1589: Net has two or more aliases that might lead...
  • State Verified Answer
  • Replies 8
  • Subscribers 58
  • Views 26597
ORCAP-1589: Net has two or more aliases that might lead to a short.
Fredda
Fredda over 4 years ago
Can't find anything useful about the ORCAP-1589 DRC warning so I'm asking here. I get this:
WARNING(ORCAP-1589): Net has two or more aliases that might lead to a short. Ensure nets are not shorted together or nets do not have two or more aliases. This message is displayed because 'Report all net names' is set in Design Rules Check dialog. U1,VCCO_PSDDR_504 VCCO_PSDDR_504 +1.1V
which is a total useless warning that I want to get rid of. I don't understand why in the first place Capture insists to use the name of the power pin of a part as an alias for the net. How can I change this or get rid of the Warning? By the way, disabling the "Report all net names" in the Design Rule Check Report Setup doesn't help, which the Warning message makes it look like.
/F
  • yksv
    yksv over 4 years ago +4 verified
    This is a legacy from when Orcad was invented 40 years ago. The "standard" was a 5V supply called Vcc or Vdd, and a positive and negative higher voltage supply for analog stuff. Instead of wiring all the…
  • nutron
    0 nutron over 4 years ago
    You could make a PCB shunt symbol to connect those two nets together.
    Shouldn't both wires have the same net name (alias) in first place anyways ?
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    You could disable this warning if not needed.
  • yksv
    +1 yksv over 4 years ago
    This is a legacy from when Orcad was invented 40 years ago. The "standard" was a 5V supply called Vcc or Vdd, and a positive and negative higher voltage supply for analog stuff. Instead of wiring all the power pins on the schematic together, Orcad decided to connect them "behind the scenes" based on their names. This was an excellent strategy for at least 10 years. For the last 20 years at least this is a pain. It forces us to declare all power pins as passive to avoid this pseudo-error. I wish Cadence would add an option to disable this feature. I am not hopeful, the software people don't really know how the hardware people work, and it seems that Cadence has a very limited budget for improvements in Capture. They still need to figure out that there is credible competition, and when the schematic capture tool changes Allegro is also no longer used.
    • Vote Up +4 Vote Down
  • Steik
    0 Steik over 3 years ago in reply to Schulz Jordan
    But disabling the warning doesn't help.
  • SergeS
    0 SergeS over 2 years ago in reply to yksv
    I completely agree, I am also looking for how to disable this warning. I am tired to correct third party symbols and make them all passive.
