  2. Allegro X Capture CIS
  3. ORCAP-1589: Net has two or more aliases that might lead...
  • State Verified Answer
  • Replies 8
  • Subscribers 50
  • Views 20153
ORCAP-1589: Net has two or more aliases that might lead to a short.
Fredda
Fredda over 3 years ago
Can't find anything useful about the ORCAP-1589 DRC warning so I'm asking here. I get this:
WARNING(ORCAP-1589): Net has two or more aliases that might lead to a short. Ensure nets are not shorted together or nets do not have two or more aliases. This message is displayed because 'Report all net names' is set in Design Rules Check dialog. U1,VCCO_PSDDR_504 VCCO_PSDDR_504 +1.1V
which is a total useless warning that I want to get rid of. I don't understand why in the first place Capture insists to use the name of the power pin of a part as an alias for the net. How can I change this or get rid of the Warning? By the way, disabling the "Report all net names" in the Design Rule Check Report Setup doesn't help, which the Warning message makes it look like.
/F
  • Wild
    0 Wild over 1 year ago in reply to SergeS
    I don't trust third party symbols or footprints.  Example of footprint issues: UltraLibraian (Not UL which is a trade mark of Underwriters Laboratory), EPads that require thermal via's are not in the padstack.  We have asked them to add them, but they told use that can't do it. Disappointed Also most of the BTC (Bottom Terminated Component) footprints don't comply with the IPC 7093A BTC Standard.
    As a reviewer I have found way to many symbols with only passive pins - avoids DRC's, but why?
  • DB202504176312
    0 DB202504176312 1 month ago in reply to yksv
    Close but not quite.  Allegro had a powerful but awkward schematic capture tool called Concept.  One of the flexibilities was each part could have a lot of properties attached, because unlike Capture, Concept connected physical parts downstream just as going to the board layout, so these properties would help specify parts from a searchable database.  Capture forces the user to select a part up front.  Thus, in Concept if you needed to increase the power handling of a resistor, you modified that property and re-ran the search.
    In this case, Concept would let you have both a netname and label for each pin.  Capture narrowed it down to just a net name property now called "Pin Name"
    To have a different graphical label for a pin, create a new pin property specfy as "Label", set it equal to "VCC" which will now appear on the part alongside the Pin Name used by Capture.  You can them make the Pin Name, in my case, "V1V2" which is my power net hidden.  So you can leave the type as "Power" and all the checks run correctly, VCC appears in the graphic, and your power nets are confirmed.
  • avant
    0 avant 1 month ago
    There's no good reason to use hidden pins or nets on a schematic symbol.
    Don't ignore or turn off the DRC's about net shorts.
    We define all power pins as passive due to these kinds of errors. Also, naming a power pin "NC" creates a net named "NC" that comes across as a net connected to all of these pins (I still see some of these on our schematics).
    We also found that defining a pin as I/O messes up the driver/receiver definitions on relative delay properties when there are multiple receiver pins tied to a single driver. We end up with multiple drivers, even when net scheduling topology is defined. We design SSD and memory modules with multiple memory devices connected to a controller.
    Stay far away from Concept. It is confusing, time consuming, and frustrating to use.
    The Capture CIS database is a powerful BOM tool. We created spreadsheet macros that will import a BOM from the schematic, sort and format components, and create the final BOM, including revision history, PWB part number, schematic part number, and hardware without having to touch the final BOM.
    The power pin issue is common. It would be great if it could be fixed.
