  2. Allegro X Capture CIS
  3. I don't see the Allegro PCB Design CIS L suite when opening...
  • Replies 11
  • Subscribers 53
  • Views 9678
I don't see the Allegro PCB Design CIS L suite when opening Orcad Capture
avant
avant over 4 years ago
When I try to open Capture, I don't see the Allegro PCB Design CIS L option. I cannot open Capture using this choice. The other suite options are always checked out.
We are using a server based license.
The software reseller has not solved our issue.
Here's what other users see as choices when opening Capture:
Here's what I see:
I cannot open Capture using the Allegro feature. I have to have someone else create netlist files for me.
We are using version 17.2 S070
Any help would be appreciated.
  • Schulz Jordan
    Schulz Jordan over 4 years ago in reply to avant
    If you are specifically facing this issue then either CDS_LIC_FILE is not set correctly or someone is using Allegro CIS license. You can ask all your colleagues to close the schematics and launch on your PC & check.
