  2. Allegro X Capture CIS
  3. Can we create 3D models in the OrCAD Library Builder
  • State Suggested Answer
  • Answers 1
  • Subscribers 52
  • Views 3515
RohitRohan
RohitRohan over 2 years ago
Dear Community,
I am using the OrCAD Library Builder and I am able to create the schematic symbols and PCB Footprints from the OrCAD Library Builder but I also want to create the Step file / 3D model in the OrCAD Library Builder.
Can we create the 3D model using the OrCAD Library Builder?
If Yes, can anyone help me with this, can anyone send me the steps / video or document to create the step file or 3D models for the footprint in the OrCAD Library Creator.
Regards
Rohit Rohan
  • steve
    steve over 2 years ago +1 suggested
    Library builder cannot create 3d step models. You need to either find the 3d step model from the component manufacturer or distributor (most of them are available now) or try 3dcontentcentral.com. The…
  • steve
    0 steve over 2 years ago
    Library builder cannot create 3d step models. You need to either find the 3d step model from the component manufacturer or distributor (most of them are available now) or try 3dcontentcentral.com. The alternative is to talk to your MCAD team who can use their tools (Solidworks, Creo etc) to make a 3d model. If you can access Cadence ECAD/MCAD Library Creator this will help with step model creation from a footprint but also can generate a footprint from a step model.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to steve
    Hai Steve,
    Thanks for the information Blush.
    Rohit Rohan
  • Robert Finley
    0 Robert Finley over 2 years ago
    I think this is the EMA product.
    A significant number of part types in OLB will build a step model along with a dimensioned drawing PDF.
    Have you tried clicking the tab that’s says “side view”?  It’s a vertical tab.  Set an override for component height first.
    that is where they buried the step export.
