  2. Allegro X Capture CIS
  3. Orcad X Capture: create a new symbol using TCL script
  • Subscribers 51
  • Views 4657
Andrey
Andrey over 2 years ago
I am a new user of ORCAD. I am trying to understand how I can create a new symbol using TCL script.
I created a new design but it is still empty. The first thing I need to do is add the ASIC chip symbol(200 pins).
I have netlist in .csv format.
I can create the symbol manually but I would like to do it using TCL script.
I will be very grateful for any help.
Thanks!
  • CadAP
    0 CadAP over 2 years ago
     Andry
    If you have csv file which contains information  Pin Number, Name, Type etc..
    Then you can read the csv and create an xml file to import in OrCAD capture to create symbol.
    You can create an xml file by trying following below step:
    1. Open a library
    2. Right click on library and select "New Part Creation From Spreadsheet".
    3. One Gui(see below screenshot) will open provide the required details and click "Save".
    Now check the location of xml file run in the Orcad capture command line .
    Open the xml file and see the information similar file need to create using tcl script .
    Hope it helps.
  • oldmouldy
    0 oldmouldy over 2 years ago
    There is no need to get involved in editing XML, New Part From Spreadsheet will allow values to be pasted directly into the grid. Open the CSV in Excel, or similar, check that the formatting for all fields is Text and then copy the column values from Excel into the Spreadsheet cells. You can have one, or multipile sections, specify the side and Pin Type in the grid if the source doesn't contain that information in a compatible form.
