  2. Allegro X Capture CIS
  3. Workspace not uploading & workspace configuration get error...
  • Subscribers 51
  • Views 3050
Workspace not uploading & workspace configuration get error "unable to get local issuer certificate"
Abdalla Saad
Abdalla Saad over 1 year ago
I have OrCAD X 24.1-2024-P001,
when open the Component Explorer and choose workspace folder, it is stuck showing "Loading Parts"
Also, when try to create a new workspace by select View > Workspace > Configuration a popup error is shown get error "unable to get local issuer certificate"
  • Jeet
    Jeet over 1 year ago
    Could you please share a screenshot of the error message you're encountering with Workspace? Specifically, which license you using POX100 or POX200 license?
  • Abdalla Saad
    Abdalla Saad over 1 year ago in reply to Jeet
    I'm using POX200 license,
    OrCAD X Capture CIS
    In catch, Error while fetching for url /workspaceapi/api/v1/getAllCloudRegions?cadenceOkta=%7B%22token%22%3A%22eyJhbGciOiJIUzUxMiIsInR5cCI6IkpXVCJ9.eyJ1c2VybmFtZSI6ImFiZGFsbGFoLnNhYWRAZWxlY3Ryb2x1eC5jb20iLCJtZmFfYXV0aGVudGljYXRlZCI6InRydWUiLCJpYXQiOjE3Mzg0OTA1ODgsImV4cCI6MTc0MTA4MjU4OCwiaXNzIjoicGNiLmNhZGVuY2UuY29tIn0.F4QDx5tC0_J9TGqY61C49aMLsXC11Da4rIVCjVKD9vdKl7V-Rf-2C-C7z0ReZq1I6W7EH5-UHC3Zv0LWNxLETg%22%7D&client=%7B%22clientid%22%3A%22eyJjbGllbnQiOiJNR1kzTW1ZeU9HRXRNVFJtTUMwME5XRXlMV0prWVRNdE16QTRNR1EzTW1NNVlXUXgiLCJ0aW1lU3RhbXAiOiJTdW4gRmViICAyIDEwOjAzOjM2IDIwMjUgR01UXG4iLCJ2ZXJzaW9uIjoiNSJ9%22%7D and error request to pcb.cadence.com/.../getAllCloudRegions failed, reason: unable to get local issuer certificate
    [ OK ]
  • Jeet
    Jeet over 1 year ago in reply to Abdalla Saad
    As it may need data sharing to debug this issue, I will be contacting you through separate channel of communication.
  • IA202512318327
    IA202512318327 over 1 year ago
    just experienced the same issue.
    any solution, I cant access/use parts in my workspace
  • Jeet
    Jeet over 1 year ago in reply to IA202512318327
    Which version of the tool you are using?, Could you upgrade to 24.1 ISR 2 and let me know if you are still facing issue.
