  3. Problems with running scripts inside skill in 16.2
  • Views 15724
Ejlersen
Ejlersen over 17 years ago
I'm trying to create a skill program for doing a lot of stuff.
I've attached my script file for generating drill files.
If I run axlShell("replay ns_drill.scr" ) from my skill window it runs fine.
If I run "skill axlShell("replay ns_drill.scr" )" from my command window inside PCB Editor it works fine.
If I however use the line axlShell("replay ns_drill.scr" ) inside a skill program it fails with "E- Can't find window; form.nc_drill"
So what is the problem here?
I'm also still curious to get the dbid of an open form? is it possible to retrieve information and do settings in an existing Cadence form somehow through Skill?
Best regards,
Ole
ns_drill.zip
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Ole,
    I think I would need to see your calling code. Are you calling the Skill in interactive or general mode? It makes a difference when calling scripts.
    I find it best to avoid running scripts from Skill. I know that's not always possible.
    I doubt that you can get the dbid of a Cadence form, it will be a local variable.
    Cheers, Dave
  • Ejlersen
    Hi Dave,
    I'll have to run through my code again to clean it up before posting, I'm creating the script from inside the skill program using axlDMOpenFile - but that does not make a difference.
    I'll check if I've remembered to set it to "general" - it may well be the problem since I'm continuing on some existing code - thanks for the hint.
    Ole
  • redwire
    redwire over 17 years ago
     Try this trick and see if it still fails
    (Set ScriptFileName to the script you want to run first)
     sprintf(runScript,"replay %s",ScriptFileName)
     axlShell(runScript)
  • Ejlersen
    Thanks for your help on this.
    I found out that my command was not registered with any ?cmdType - and hence defaults to interactive. So setting it to general fixed the problem.
    I'll however try the suggestion with the axlShell(runScript) also, sometimes assigning to a variable first fixes some problems.
    Best regards,
    Ole
