  3. how to share license with VPN?
  • Views 30324
Biaohu
Biaohu over 16 years ago
I installed cadence spb16.2 in compony(server licensed) and installed cadence in home(no license), also i have a vpn to set a connection to the compony's network. now, i want to know can i share the server license in home with VPN connection? And how to do? Thank you!
  • Biaohu
    No body knows?
  • DE202408202727
    DE202408202727 over 16 years ago
    Yes, this will work. You don't have to do anything special. Your home PC will "see" the license server.
    However, you should check your license agreement. Using a VPN connection, off campus, may not be permitted.
  • Biaohu
    Thanks eDave, and i have done. And next is my steps:
    1.Get the server host ID in your compony's license server.
    2.install the cadence in your personal PC normally.
    3.add the configuration5280@host id with the tool named license client configuration utility.
    4.setup the connection with VPN.
    so, your personal PC will find the license.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Just a side note, if your license server has a fixed ip adress it is worth using 5280@ipadress.
    Best regards
    Ole
  • Biaohu
    ok, i remember this suggestions, thanks a lot!
