  3. Temporary highlight
  • Replies 11
  • Subscribers 159
  • Views 18777
Temporary highlight
Khurana
Khurana over 14 years ago
Is there a way to find out the dbid of an object that's temporary highlighted?  If yes, how - thanks!
  • Silver John
    Silver John over 14 years ago
    Get all objects, check theirs with axlIsHighlighted() function, then check for color is used for temporary highlighting (how get temporary highlight color I don't know).
    Or may be highlighted objects are in the select set? Try getting select set.
  • Khurana
    I invoked axlIsHighlighted() on highlighted symbols and it returned nil...same for symbols that were assigned a color using Display > Assign Color command - any other ideas?
  • Randy R
    Randy R over 14 years ago
    Try what Silver John said at the end, get the select set; axlGetSelSet().
  • Silver John
     Yes, my mistake.
     axlIsHighlighted
    Description
    If the object is permanently highlighted returns the highlight color; otherwise nil.
    And this work for permanently highlighted objects.
    <code>
    ; permanent highlight any symbol using Display > Assign Color (I use yellow)
    axlSetFindFilter(?enabled '(GROUPS SYMBOLS PINS VIAS TEXT NAMEFORM ) ?onButtons '(SYMBOLS)) ; filter
    axlSelect(?groupMode nil ?prompt nil)
    ; now select symbol
    _selectedObjects = axlGetSelSet() ;
    ; now _selectedObjects contains LIST of objects
    axlIsHighlighted(_selectedObjects)
    ; -> nil
    axlIsHighlighted(car(_selectedObjects))
    ; -> 8
    ; now we have object id in _selectedObjects. Exit from any commands, deselect any objects
    ; -> 8
    </code>
  • Silver John
     2 Randy
    In idle state we can select any objects, and they are be highlighted but not in the select set.
    2 Khurana
    What is your final goal?
