  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120532
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • DE202408202727
    0 DE202408202727 over 7 years ago in reply to dvkumar
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/EDAVE_5F00_clearPinSilk.zip
  • dvkumar
    0 dvkumar over 7 years ago in reply to DE202408202727
    Dave,
    Thanks for the file, When I run the skill it shows the below Error and there is a path with 64bit    text which is not in the actual path of the context file.
    Command > aline
    radius:11.0
    E- *Error* loadContext: could not open file - "C:/Users/Mypc7894/Desktop/chks/64bit/EDAVE_clearPinSilk.cxt"
    Command >
    Would you please help me to fix this.
    Thanks again,
    Dvk.
  • DE202408202727
    It's a quirk of the 32bit/64bit conflicting requirements that you need to place the cxt file in the 64bit folder.
  • tmd63
    0 tmd63 over 7 years ago
    Doesn't the autosilk do this in Allegro? At least for the outlines!
  • dvkumar
    Hi Dave,
    Thanks for the guidance. It is working now. Thanks again.
    Dvk.
