  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120539
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • GK MN
    0 GK MN over 7 years ago in reply to DE202408202727
    Hello
    I do face same problem , you mentioned place the  cxt in 64bit folder ,i placed it under  C:\Program Files but its showing below error.
    please help me on this . This is a great skill utility using it  from so many years and addicted to it !
  • DE202408202727
    0 DE202408202727 over 7 years ago in reply to GK MN
    You need to put the file in a 64bit folder in your Skill path. So if your site points to c:\mycadence\pcb your cxt file needs to be in c:\mycadence\pcb\64bit
  • madhesh
    0 madhesh over 7 years ago in reply to DE202408202727
    Hi Dave,
    we need to custom spacing of clearPiSilk. how can I do ? Please help us.
  • GK MN
    0 GK MN over 7 years ago in reply to GK MN
    Thank you very much for reply . But somehow i am unable to make it working  Disappointed .. tried many ways
    below is my setup for skill routine , if you observe anything I am missing please help me to rectify the same, it will be a great help
    17.2 installed under directory  C:\Cadence\SPB_17.2
    PCB ENV file and allegro.ilint located at path :C:\Cadence\DYNAMIC_MENUS\PCBENV
    allegro .ilint updated with command
    load ("EDAVE_clearPinSilk.cxt")
    axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk ?cmdType "interactive")
    axlCmdRegister("assembly lines to silk" 'EDAVE_assemblyToClearPinSilk ?cmdType "interactive")
    Skill file path  : C:\Cadence\SPB_17.2\share\local\pcb\skill
    Environment variable  : ALLEGRO_PCB_ENV  set to C:\Cadence\DYNAMIC_MENUS\PCBENV
    I kept EDAVE_clearPinSilk.cxt file  at C:\Cadence\SPB_17.2\share\local\pcb\skill
    My all other skill routines working file except this one , i didn't had any issue with version 16.x only with 17.x facing problem
    also error screenshot attached
    Girish Kumar
  • DE202408202727
    You MUST place it in a 64bit folder. (C:\Cadence\SPB_17.2\share\local\pcb\skill \64bit)
