  3. Clear silkscreen from pins in Allegro Package
  • State Suggested Answer
  • Replies 110
  • Answers 2
  • Subscribers 177
  • Views 120546
chads108
chads108 over 14 years ago
 Does anyone have some SKILL code that will clear silkscreen lines back x distance from pins, either as a group or individually?  I want to use this during footprint building.  Currently I have to use delete and cut to remove pieces of lines that run through pads.
  • DE202408202727
    DE202408202727 over 14 years ago +3 suggested
    See attached. It's a context file in the meantime. Load it by using the commands: In Skill (or allegro.ilinit): loadContext("EDAVE_clearPinSilk.cxt") axlCmdRegister("clear pin silk" 'EDAVE_clearPinSilk…
  • DE202408202727
    DE202408202727 over 4 years ago in reply to PK1234 +2
    community.cadence.com/.../3343.EDAVE_5F00_clearPinSilk.zip Hopefully the attached revision has sorted the problems
  • oldmouldy
    oldmouldy over 14 years ago +1
    Surely, when designing the symbol, you don't draw the silkscreen over the pins anyway??
  • NNONN
    0 NNONN over 6 years ago in reply to DE202408202727
    Hi Dave,
    Please share the 17.4 version of the EDAVE_clearPinSilk.cxt
  • DE202408202727
    0 DE202408202727 over 6 years ago in reply to NNONN
    Sorry. I can't do that at the moment.
  • Manikandaprabhu
    0 Manikandaprabhu over 6 years ago in reply to DE202408202727
    • Hi Dave, I try to Load EDAVE_clearPinSilk.cxt. I got an error  "'*Error* loadContext: could not open file - "64bit/EDAVE_clearPinSilk.cxt". Please provide me step load context file. I have using version 17.2.
  • PK1234
    0 PK1234 over 4 years ago in reply to DE202408202727
    Can you please just share Skill code, so we can modify it to meet our requirement?
  • DE202408202727
    0 DE202408202727 over 4 years ago in reply to Manikandaprabhu
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/3730.EDAVE_5F00_clearPinSilk.zip
    Please try this 17.2 version.
