  3. axlDBCreateShape attach to via?
  • Replies 7
  • Subscribers 159
  • Views 14862
Ejlersen
Ejlersen over 11 years ago
Hi
I've used axlDBCreateShape and attached it to a symbol with succes in the past.
Now I would like to be able to do the same for a via but seems like this is not possible or is there a way to do this?
Best regards
Ole
  • jwhend
    jwhend over 11 years ago
    axlSymbolAttach() should do the trick.
    --Jerry
  • Ejlersen
    Hi Jerry
    I'm sorry but that won't work in this case.
    I don't want to attach the via to a symbol, I want to attach a shape to a via so that If I move the via then the shape gets moved together with the via.
    I'll be using this to create a custom layer under Manufacturing for a resized mask layer depending on either an existing mask or etch layer.
    Creating the resized shape is no hassle, all coding is done, my concern is that if a via is moved after running the resize functionality then I have a mask openening in a place where there should be no mask opening, hence the need to attach it to the via.
    Best regards
    Ole
  • jwhend
     Can you make the shape and vias a group, then fix them?
    axlDBCreateGroup?
  • Ejlersen
    Hi
    I guess my only option is to copy existing padstack ids and during that process add a custom layer and replace padstacks, it could have other impacts since an Update padstack would replace, but I'll have to live with that
    Thanks for your suggestions
    ole
  • eDave
    eDave over 11 years ago
    Hi Ole,
    Have you considered creating a symbol on the fly to do this?
    Dave
