  3. File-Export-PDF needs license?
  • Replies 10
  • Subscribers 166
  • Views 25942
redwire
redwire over 7 years ago
After just upgrading everyting to V17 I noticed that the File->Export->PDF is not functional in OrCAD Pro.  Is this a special license that I missed?  It's the only menu tree item that does not work for me.
  • B Bruekers
    B Bruekers over 7 years ago in reply to DavidJHutchins +3
    Yes, sadly they removed the 'free' PDF creation since HF49 or 50. As I have been told this has to do something with licencing of a 3rd party tool to create the actual PDFs. For now they don't know when…
  • DavidJHutchins
    DavidJHutchins over 7 years ago +2
    I believe it requires a 'Allegro_Design_Publisher' license
  • steve
    steve over 6 years ago in reply to B Bruekers +2
    Just as a FYI Export PDF is back again without a license. Available in 17.2-2016 S065 and 17.4-2019 S005..
  • DavidJHutchins
    • Vote Up +2 Vote Down
  • redwire
    redwire over 7 years ago in reply to DavidJHutchins
    I see on Cadence that that license is for schematic publishing PDF not for layout.  That is the issue...but you might be right.  I'll see what the VAR says.
    <edit>  The VAR responded with the same as what David said above:  Needs Design Publisher license...sigh..
  • excellon1
    excellon1 over 7 years ago
    Hi in Orcad PCB STD version 17.2 S047 The PDF Export is working fine.. What service pack did you update to ?
  • redwire
    redwire over 7 years ago in reply to excellon1
    I am at S033.  I'll go try the later hotfix and see.  Thanks for the heads-up
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to redwire
    I just installed the latest hotfix:
    \t (00:00:01) allegro 17.2 S051 Windows SPB 64-bit Edition
    however 'pdf out' still fails for me since I don't have the ''Allegro_Design_Publisher' license:
    \i (00:00:11) pdf out
    \t (00:00:11) No license found, please contact your Cadence sales support.
    \i (00:00:14) fillin confirm
