  3. Interactive delay tuning help
  • Subscribers 166
  • Views 11718
coronas
coronas over 4 years ago
I created a match group of nets in constraint manager -> relative delay section
When I use the delay tune command this indicator pop-up
I cannot understand the meaning of these numbers and bars:
-totE is similar to total etching value but in constraint manager it says 124mm not 127mm, there is always discrepancies
-RDly shows two numbers, a negative and a positive one, what does it mean?
what is the measure unit of these numbers?
can I change the numbers to be shown?
  • steve
    0 steve over 4 years ago
    RPD_Heads-up.pdf
    This may help
  • avant
    0 avant over 4 years ago
    In constraint manager, select Analyze / Electrical
    Make sure the Z-axis delay box is not checked. I ran into this last week. The measured line lengths were not matching the lengths shown in constraint manager.
    The Z-axis delay adds the depth length of the via between layers.
