  3. How to add SMT test points ?
  • State Verified Answer
  • Replies 8
  • Subscribers 170
  • Views 16154
SOT23
SOT23 over 4 years ago
Hello !
I am trying to add SMT test points to a board but couldn't find a way to do that. I tried :
  • creating a single SMT pin footprint that I manually added, but I can't easily set a net to it to make it a test point.
  • creating a SMT via (just a 0.6mm circle on bottom layer), but I cannot add them to the board. I can add them to the Via list in the Physical Constraints Manager, but when I try to add them by using the Cline command (like I would do to add a THT via), it doesn't work, the SMT via doesn't appear in the list...
How could I simply add an SMT via to the board ?
Thank you !
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 verified
    While in the 'add connect' command, in the Options tab, set both layers to 'Bottom', then the only via that should be available is the SMT via It works for me...
  • DavidJHutchins
    +1 DavidJHutchins over 4 years ago
    It works for me...
  • smithbend
    0 smithbend over 4 years ago
    Fantastic article. Outstanding reading material It's fantastic to read blogs this good. Thanks! If you want to, rock.
    among us
  • SOT23
    0 SOT23 over 4 years ago in reply to DavidJHutchins
    It works great ! Thank you !
  • SOT23
    Still on the topic of Test Vias :
    Does anyone know if it is possible to add a Placebound to a Test Vias ?
    I tried adding a layer in the padstack definition, but I cannot add constraint to it. Is it possible to define that layer so that it acts like a placebound ?
  • jc teyssier
    0 jc teyssier over 4 years ago in reply to SOT23
    For what purpose?
    To have a place boundady the test point have to be a component from schematic/netlist.
    If goal is only not to have tres point under compoennt, just set testpoint parameters correctly (do not allow under components)
