  3. Same net shape to via spacing when a via edge touches the...
  • Replies 10
  • Subscribers 167
  • Views 16670
Same net shape to via spacing when a via edge touches the shape: how to set the shape to void the via edge?
avant
avant over 4 years ago
If a via touches the edge of a shape on the same net, how to set the shape to void around the via?
  • JuanCR
    JuanCR over 4 years ago +1
    Hi What exactly do you mean? This is what I understand you want to do: You have a via that touches a shape and they both belong to the same net: As you can see in the picture, there is full contact…
  • avant
    avant over 4 years ago in reply to JuanCR +1
    The edge of a via is touching the edge of a same-net shape. The center of the via is not within the shape. The shape is not voided to remove the small copper sliver. The vias need to have full contact…
  • avant
    avant over 4 years ago in reply to avant +1
    Here's an example.
  • JuanCR
    Hi
    As you can see in the picture, there is full contact between the via and the shape. I think you want it to look like this:
    With a thermal relief ...
    If this is the case, there are several ways to do it depending on how global you want the change to be. You can go to Shape > Global Dynamic Params... and modify this for all shapes in the design. Or you can go to Shape > Layer Dynamic Params... and change it for each layer.
    Last but not least, you can Shape Edit Mode:
    Then, whenever you select a shape, you can right click and you'll see this option:
    No matter what you choose, the interface will be the same:
    Go to the Thermal Refief connects tab and change the Vias field.
    I hope this was what you were looking for
  • avant
    The shape is not voided to remove the small copper sliver. The vias need to have full contact, not thermal ties.
    I usually look for these on my designs and adjust the shapes. I want an automatic shape void or DRC solution.
  • avant
    Here's an example.
  • Bennigin
    Bennigin over 4 years ago in reply to avant
    Trying setting via-to-shape same net spacing constraint to a value like 4mils.
  • avant
    avant over 4 years ago in reply to Bennigin
    Thanks, I tried that, but it does not solve my problem.
