  3. Retaining component nets after changing the origin
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 10544
Apexter
Apexter over 4 years ago
I have a Footprint placed in PCB for which I have changed the Origin from Pin 1 to body center. When I update the footprint in PCB Editor the nets are getting ripped off. I want to know is there any procedure to update the symbol without affecting the nets.
I am using OrCAD PCB Designer Professional - 17.4 S033
  • JuanCR
    0 JuanCR over 3 years ago
    When changing the origin of a symbol, PCB Editor moves the placed symbol so that the new origin coincides with the old origin position. So, as a result, there will be ratsnests that will appear once the you update the symbol.
  • masamasa
    0 masamasa over 3 years ago
    u can simply move the origin without updating the symbol by chaning the value of the "move origin" setting on the design parameter editor.
  • avant
    0 avant over 3 years ago
    Query and record the coordinates of pin 1.
    When updating the part, ensure rip up traces is turned off.
    After the part update, move the part by pin # (1) and place it per the original pin 1 coordinates.
