  3. DB Doctor download?
  • State Verified Answer
  • Replies 37
  • Answers 1
  • Subscribers 183
  • Views 62482
DB Doctor download?
GuidoU
GuidoU over 2 years ago
Any one know where to download or access DB Doctor?
Need to convert a .brd file from 16.6 version to 17 version....
Guido
  • JuriV
    JuriV over 2 years ago in reply to John T +3
    Hi JohnT, I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro…
  • John T
    John T over 2 years ago in reply to nuPoli2023 +2 suggested
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1? I can then send you the appropriate program by mail once confirmed.
  • John T
    John T over 2 years ago in reply to andyz2024 +2
    No problem Andy. If you now have installed an older viewer which works, please share the link here for others to use.
  • John T
    0 John T over 2 years ago in reply to murphy wakasi
    Hi murphy wakasi, I will need to know your current installation version in order to send you the correct db doctor version - and your email address. It is not possible this to the forums page.
  • MCMocoder
    0 MCMocoder over 2 years ago in reply to John T
    As I know,version 23.1 will throw this error and show it in the "view log" window of PCB DB doctor 2023
  • YannCDK
    0 YannCDK over 2 years ago in reply to John T
    HI John T,
    i have the same error, but i don't have the pcb doctor in the cadence pcb utilities file
    I'm using Allegro 23.1
    Yann
  • John T
    0 John T over 2 years ago in reply to YannCDK
    Hi YannCDK, do you have a link to the installation pack you have used? I would appreciate if you could copy the link here. The Allegro Editor installation always comes with dbdoctor. If something has gone wrong with this then we would like to understand why and rectify. Please confirm if it is the full pcb editor you have installed or just the free viewer.
    In the Allegro Editor, you should be able to run dbdoctor using the menu shown below. This should be possible to run even using a new unnamed design. Can you please check if you can run this from the editor?
  • biasedMOS
    0 biasedMOS over 2 years ago
    Hello, I have the read only version, Allegro Free physical Viewer. Would it be possible to access DB Doctor and download it? I have the same issue.
