  3. DB Doctor download?
  • State Verified Answer
  • Replies 37
  • Answers 1
  • Subscribers 183
  • Views 62512
DB Doctor download?
GuidoU
GuidoU over 2 years ago
Any one know where to download or access DB Doctor?
Need to convert a .brd file from 16.6 version to 17 version....
Guido
  • JuriV
    JuriV over 2 years ago in reply to John T +3
    Hi JohnT, I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro…
  • John T
    John T over 2 years ago in reply to nuPoli2023 +2 suggested
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1? I can then send you the appropriate program by mail once confirmed.
  • John T
    John T over 2 years ago in reply to andyz2024 +2
    No problem Andy. If you now have installed an older viewer which works, please share the link here for others to use.
  • John T
    0 John T over 2 years ago in reply to andyz2024
    Hi Andy, I have sent you a friendship request so that we can connect directly to transfer an older viewer installation. Please respond to me by direct email.
    I have now installed and tested this older viewer and it installs and works on an isolated machine.
  • andyz2024
    0 andyz2024 over 2 years ago in reply to John T
    Hello John, thanks for your quick response, I have gotten this version from website,
  • John T
    • Vote Up +2 Vote Down
  • John T
    0 John T over 2 years ago in reply to CappedOut63
    Apologies for the delay replying to your comment. If you have not seen the discussion on other forum threads already then please see the link below explaining where dbdoctor is already located in the OrCADX 23.1 installation:
    community.cadence.com/.../db-doctor-23-1-download
    This is separate to concerns about the free viewer which does not come with the dbdoctor tool.
  • JuriV
    0 JuriV over 2 years ago
    Hi everybody,
    I have the same problem with Orcad Pcb designer 23.1.
    The message:
    Cannot load symbol 'SMR0805'
    because WARNING(SPMHUT-127): Could not find padstack SM_LLB_PAD5_1.
    The design was last saved using version 16.5 and must be updated using DB Doctor
    This appears with all Footprints and Padstacks in my own library. The solution is: run DBdoctor for all Footprints.
    Is there a way to check (dBDoctor)
    all files (dra. or pad.) at once?
    Thank you
    JuriV
