  3. DB Doctor download?
  • State Verified Answer
  • Replies 37
  • Answers 1
  • Subscribers 183
  • Views 62515
DB Doctor download?
GuidoU
GuidoU over 2 years ago
Any one know where to download or access DB Doctor?
Need to convert a .brd file from 16.6 version to 17 version....
Guido
  • JuriV
    JuriV over 2 years ago in reply to John T +3
    Hi JohnT, I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro…
  • John T
    John T over 2 years ago in reply to nuPoli2023 +2 suggested
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1? I can then send you the appropriate program by mail once confirmed.
  • John T
    John T over 2 years ago in reply to andyz2024 +2
    No problem Andy. If you now have installed an older viewer which works, please share the link here for others to use.
  • Ulf K
    0 Ulf K over 2 years ago in reply to JuriV
    Yes there is a method for doing this. A separate executable in the tools\bin folder. Search the internet. There are several answers to this question. I used that method in order to upgrade an entire library some time ago. The program browses through all files, opens them, checks them and writes back the upreved library files. It will take some time but you will not have to uprev each individual item manually.
    • Vote Up +2 Vote Down
  • John T
    0 John T over 2 years ago in reply to JuriV
    Hi JuriV, try searching for the allegro_uprev utility. You can type into the windows command prompt: "allegro_uprev -help" for a detailed breakdown of the utility
  • JuriV
    0 JuriV over 2 years ago in reply to John T
    Hi JohnT,
    I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro\Footprints\*.*. All Files in the library will be checked. After then thats works error free.
    • Vote Up +3 Vote Down
  • John T
    Perfect thanks Juriv !
  • AB_1718766250744
    0 AB_1718766250744 over 2 years ago
    Hi all
    I have same issue .
    My allegro version was 23.1 , but I didn't find the db doctor in my file.
    could you help me?
    thanks
