  3. DB Doctor download?
  • State Verified Answer
  • Replies 37
  • Answers 1
  • Subscribers 183
  • Views 62517
DB Doctor download?
GuidoU
GuidoU over 2 years ago
Any one know where to download or access DB Doctor?
Need to convert a .brd file from 16.6 version to 17 version....
Guido
  • JuriV
    JuriV over 2 years ago in reply to John T +3
    Hi JohnT, I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro…
  • John T
    John T over 2 years ago in reply to nuPoli2023 +2 suggested
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1? I can then send you the appropriate program by mail once confirmed.
  • John T
    John T over 2 years ago in reply to andyz2024 +2
    No problem Andy. If you now have installed an older viewer which works, please share the link here for others to use.
  • John T
    +1 John T over 2 years ago in reply to AB_1718766250744
    Hi AB, you should find this utility in the folder "...\tools\bin" in your install directory. Example C:\Cadence\OrCADX_23.1\tools\bin
    The utility is called dbdoctor_ui.exe and the ui is intuitive. Simply load the older design and select the location to drop the new version.
  • PA202502037445
    0 PA202502037445 over 1 year ago in reply to Jim OMahony
    please help me. i need db docktor
    thanks
  • JV202507141359
    0 JV202507141359 over 1 year ago
    I am having the same issue using the free viewer version. Could I get a link to an older version of the free viewer in order to access the .brd files I am trying to view? The .brd files were made in 16.6 version.
    Thank you.
  • John T
    +1 John T over 1 year ago in reply to JV202507141359
    Please try this: https://www.cadence.com/ko_KR/home/tools/pcb-design-and-analysis/allegro-downloads-contact.html or https://www.cadence.com/en_US/home/tools/pcb-design-and-analysis/allegro-downloads-contact.html Enter your basic details into the form provided. Make sure to select the free viewer checkbox in the selection of Allegro Free Downloads. Click Submit and the download should start.
    • Vote Up +2 Vote Down
  • JV202507141359
    0 JV202507141359 over 1 year ago in reply to John T
    Both of these are for version 24.1. I need an older version that supports files created with version 16.6.
