  3. DB Doctor download?
  • State Verified Answer
  • Replies 37
  • Answers 1
  • Subscribers 183
  • Views 62520
DB Doctor download?
GuidoU
GuidoU over 2 years ago
Any one know where to download or access DB Doctor?
Need to convert a .brd file from 16.6 version to 17 version....
Guido
  • JuriV
    JuriV over 2 years ago in reply to John T +3
    Hi JohnT, I use Orcad PCB Designer and I Think allegro_uprev utility is not licensed. But it's possible to use DBDoctro for complete directory. The path must be entered manually e.g. :\Cadence\Allegro…
  • John T
    John T over 2 years ago in reply to nuPoli2023 +2 suggested
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1? I can then send you the appropriate program by mail once confirmed.
  • John T
    John T over 2 years ago in reply to andyz2024 +2
    No problem Andy. If you now have installed an older viewer which works, please share the link here for others to use.
  • dhinesh
    0 dhinesh over 1 year ago
    If anyone still facing this issue, I found a solution.
    Note: This is for people who have this issue but don't have a cadence software suite or license. The ideal solution would be using the DB Doctor software but that requires a cadence license.
    https://www.indiafix.in/2024/05/allegro-free-physical-viewer-166.html
    You can download the 16.6 version of Allegro Free Physical Viewer from this link. I can open the .brd files generated from 16.6 allegro without any issues.
    • Vote Up +2 Vote Down
  • PV202510306338
    0 PV202510306338 over 1 year ago
    Hello, I'm still having the same issue. I have the version 25.1 installed, and got the same message saying that the design was last saved using version 16.6 and must be updated using DB Doctor. I only have the free PCB viewer. Is it possible to provide the DB Doctor?
  • CT20260410501
    0 CT20260410501 7 months ago in reply to PV202510306338
    I am receiving the same error and looking for support here.  With the free viewer is their no way to view outdated design files?
  • Rita Fung
    0 Rita Fung 4 months ago in reply to John T
    Hello John, I'm looking for the solution.
    the Allegro X free viewer version I'm using is 24.1 -  the latest version available.
    I need to open files which are 16.6 version.
    Thanks.
  • John T
    0 John T 4 months ago in reply to Rita Fung
    Hi Rita, I have discussed this in our technical team to check for another solution. Dbdoctor is not available as a standalone. Ideally the best solution would be to provide an older version of the freeviewer. A secondary option is that I can convert the design for you. I will friend request you on the community so we can exchange data by pm.
