  3. Allegro. create Asymmetrical KEEPOUT area around CONNECTOR...
  • State Suggested Answer
  • Answers 1
  • Subscribers 172
  • Views 6259
Allegro. create Asymmetrical KEEPOUT area around CONNECTOR in Constraint MANAGER
grax
grax over 2 years ago
Hi
I want to create an asymmetrical  KEEPOUT area around a connector (Conn1) inside CONSTRAINT MANAGER; which is the best way to do it?
In Constraint MAnager > SPACING > REGION >>  I create a SPACING_Region and define minimum spacing to SMD but in this case also Conn1 will rise a DRC violation
Thanks for your support
L
  • excellon1
    0 excellon1 over 2 years ago
    Hi, it sounds like you want to have an area around CONN1 so that if a component is placed too close to CONN1 then a DRC will be produced ?
    In such a case this is easily handled by Package Spacing.
    In the pcb editor turn on Package Geometry > Place Bound Top so the place bound is visible. In the find filter check Shapes, Next click on the shape selection tool and then
    click on the place bound shape and extend that shape to the size of the area you want as a keepout. When finished right click and choose done.
    If you move any component too close to CONN1 it should produce a drc.
    See if that will work for you.
  • JB20240922859
    0 JB20240922859 over 2 years ago
    1. Define a Region: Go to Constraint Manager > Spacing > Region and create a new Spacing_Region.
    2. Adjust Spacing: Set the minimum spacing for specific object types like SMDs. bitlife
    3. Exempt Connector (Conn1): To avoid DRC violations for Conn1, you may need to manually exclude or adjust the constraints specific to that connector in the region settings.
  • grax
    0 grax over 2 years ago
    best solution is just to add any number of HOLES inside the KEEPOUT area so no DRC will be rosen
