  3. update layout creates a Rectangle "Board Geometry/Top_Room...
  • State Verified Answer
  • Replies 24
  • Answers 2
  • Subscribers 172
  • Views 12326
update layout creates a Rectangle "Board Geometry/Top_Room" that cannot be removed
JC202409239850
JC202409239850 over 2 years ago
This is my first time designing my PCB with Cadence tools. I placed several parts on the PCB design, then I went back to the schematic to make some changes to the connectors. When I came back to the PCB editor and selected "update layout", the editor added all the parts that were not yet placed in a rectangle region named "1". The rectangle cannot be deleted with Edit->Delete command. Can anyone give some hints on how to remove it?
  • John T
    John T over 1 year ago in reply to Zhifeng Jin +3 verified
    Hi Zhifeng thanks for sending this. I have managed to delete this room. It turns out to have been assigned a "fixed private" state. We will investigate this further in the tool. For now the fix is to…
  • FaPb
    FaPb over 1 year ago in reply to EStedt +2
    Run Tools > Database check. Then delete it as a shape. That worked in my case.
  • John T
    John T over 2 years ago +1 suggested
    Hi JC, to remove rooms please use menu: Setup > Outline > Room Outline. To setup the board outline you should also invoke the Design Outline setup tool from the setup menu before placing any compo…
  • B Bruekers
    0 B Bruekers over 1 year ago in reply to John T
    Another way is to delete this property by some skill commands.  In the normal command line:
    skill axlDBDeleteProp(axlDBGetShapes( "BOARD GEOMETRY/TOP_ROOM") "FIXED_PRIVATE")
    Then all properties are removed.
    Next step is disband any group. After this you can delete the rectangles.
  • Timor77
    0 Timor77 over 1 year ago in reply to John T
    Sorry for the late reply. I was away. This also worked for me. Thanks.
  • John T
    0 John T over 1 year ago in reply to B Bruekers
    Me too - thanks B Bruekers!
  • PD20250807594
    0 PD20250807594 2 months ago in reply to FaPb
    Worked for me. After Run Tools > Database check > Check shape outlines, i was able to right click > delete.
