  3. I can only run Allegro PCB in safe mode
  • State Verified Answer
  • Subscribers 166
  • Views 6505
kevcon
kevcon over 2 years ago
Hi all,
I think something got corrupted on my machine, I can run Capture CIS with no issues, but I can only run Allegro PCB in safe mode. I cannot run Presto PCB at all, both Allegro PCB and Presto PCB say they can't find the license server when started normally.
I have tried repairing and reinstalling the software with no luck.
Any suggestions?
  • kevcon
    kevcon over 2 years ago in reply to excellon1 +1 verified
    Something was corrupted in the PCBENV directory; after deleting it everything works as it should.
  • kevcon
    0 kevcon over 2 years ago
    Ok, I ended up deleting the pcbenv directory and everything looks like it is all good now.
  • excellon1
    0 excellon1 over 2 years ago
    If you can run Capture then that means that capture is finding where the license is. There is not much information in your post as to what type of license server you have.
    The license Server can be run locally on your local PC or it can be run on a server that resides on your network. Which one ?
    By the sound of your post it sounds like Presto or the version of Allegro you have is not licensed or the actual license file does not contain these options. When launching
    Allegro if you choose a version of Allegro that is not licensed an error will be produced....
    Things to check for would be.
    1 What products did you license and does the actual license file contain them.
    2 Where is the License Server. It can be on your Local PC or on a Network server location. ?
    3 When installing Allegro it is best to install it "For All Users"
    Maybe you can clarify the above ?
    Best Regards.
  • kevcon
    +1 kevcon over 2 years ago in reply to excellon1
  • Robert Finley
    0 Robert Finley over 2 years ago
    There are license cache files in pcbenv that definitely need a purge if you add Orcad to an Allegro user.
    But, if you nuke your pcbenv directory, you lose your config files.
    • env file, which has my aliases and library paths.
    • allegro.ini
    License Server properties are stored in the Windows system environment variables.   Haven't found any mention in pcbenv.
    CDS_LIC_FILE is the most important property which points to server(s) and a TCP port.  You can list alternate servers separated by semicolons.  But, they should be constantly active or you will wait until the timeout expires before it checks the next machine on the list.
    Check for duplicate properties between Windows User Variables as it overrides Windows System Variables.
    If you install the 30 day demo for Orcad X 23 to play with Presto, normal licensing won't work again until the following windows variables are REMOVED.
    • CDS_LISTENER_MODE = LOCAL
    • Allegro_license_mode = single_user_licensing
    Delete these.  Please.  Uninstalling the demo does not fix this.
