  3. Does OrCAD have an interactive HTML BOM feature like Kicad...
  • State Suggested Answer
  • Answers 1
  • Subscribers 167
  • Views 7166
Does OrCAD have an interactive HTML BOM feature like Kicad?
Krutik
Krutik over 1 year ago
Does OrCAD have an interactive HTML BOM feature like the Kicad?
Currently I am using OrCAD 22.1 PCB Editor.
Thank you.
  • techiecs
    techiecs over 1 year ago +1 suggested
    One way to generate BOM in OrCAD PCB Editor is by going to menu Export> Quick Reports> Bill of Material Report, however this BOM report generated won't be an Interactive BOM Report For Interactive HTML…
  • techiecs
    0 techiecs over 1 year ago
    For Interactive HTML BOM feature in PCB Editor, you may want to explore Variant BOM application which offers the ability to create reports for the core design.
    This report can be obtained using the Allegro Productivity Toolbox product option which needs to be purchased separately. The report can be obtained using the Productivity Toolbox's "tbx varibom" command.
    Variant BOM is a general purpose report generator. Thus it can be used to generate reports also on designs where no variants were specified.
    Three different file formats can be specified- a formatted text file, a csv file and an HTML file can also be generated, and click on 'Show Report' against HTML format while generating the BOM Report which opens it in a separate window wherein you click on any Refdes from the report and the corresponding Refdes gets highlighted in the OrCAD PCB Editor design canvas.
  • Krutik
    0 Krutik over 1 year ago in reply to techiecs
    Thank you for the suggestion.
    Could you please provide a link to the Variant BOM application or where I can download it, as I am unable to find it online?
  • Robert Finley
    0 Robert Finley over 1 year ago
    Now, variant manager is an integral part of the CIS option for Orcad.  This is the key to generating different BOMS for the same artwork that don't need editing (zero-touch.)
    My take on this feature of KiCAD:  split screen view of the BOM list and the board layout. Select a line item on the BOM and it highlights the parts on the layout sharing the same MPN.  Useful for hand-stuffing bare boards, which we don't do.
    The only method I can think of:  If you have access, Downstream Blueprint tool is useful to generate assembly drawings with pcb views having polarity/pin1's highlighted.   Add a second view that highlights noStuff parts to validate our variants for values that are unknown until the board is tuned and for noLoad of entire blocks.
  • techiecs
    0 techiecs over 1 year ago in reply to Krutik
    Variant BOM can be started from Pulldown menu in Allegro or by entering the command tbx varibom in the commmand window of Allegro itself.
    Variant BOM report generation requires using Allegro Productivity Toolbox product option in Allegro and which needs to be purchased separately.
  • Krutik
    Ohk, Thank you for the solution.
