  3. MAX File import in OrCAD PCB 24.1
  • State Suggested Answer
  • Answers 2
  • Subscribers 168
  • Views 5954
JuriVi
JuriVi over 1 year ago
Hello everybody,
is there any way to import old Layout MAX Files into the OrCAD PCB Designer 24.1?
In "File-->Import--> CAD Transllators" this option no longer there.
Tahnks and best regards
JuriV
  • steve
    steve over 1 year ago +1 suggested
    You can still do this if you have access to version 22.1 or older. Remember to enable the User Preference (Setup - User Preferences - unsupported - layout2allegro_unsupported) and restart the tools, you…
  • oldmouldy
    oldmouldy 4 months ago in reply to drmc715 +1
    There was an error in the previous post. The last supported version for the OrCAD Layout max import was 17.4-2019 Bear in mind that OrCAD Layout was end of life at the end of March 2009, so the 32-bit…
  • vidhyaparameswari
    0 vidhyaparameswari over 1 year ago
    Hi JuriV,
    The File>Import>CAD Translators>Orcad In option is no longer available , since we are not supporting MAX files anymore.
  • steve
    0 steve over 1 year ago
    You can still do this if you have access to version 22.1 or older. Remember to enable the User Preference (Setup - User Preferences - unsupported - layout2allegro_unsupported) and restart the tools, you can then see it under the CAD Translators menu.
  • Ulf K
    0 Ulf K over 1 year ago in reply to vidhyaparameswari
    IMO removing/dropping old features such as MAX import is a bad decision. The same thing goes for older releases of DBDoctor Keeping an old outdated feature could have been done by simply stating that "This feature is version XX.x and is not supported. It is available only at the users own risk. Cadence assumes no warranties whatsoever regarding its functionality."
    Importing/converting old formats or formats from competitors is a competitive advantage. With disclaimers as above, without any cost.
  • drmc715
    0 drmc715 4 months ago in reply to steve
    Hello. I'm trying the same thing as the OP. I have 25.1 installed and installed 22.1 (22.1-2022 S012) just to try this and I can't see this preference in the unsupported list.
  • oldmouldy
    0 oldmouldy 4 months ago in reply to drmc715
    There was an error in the previous post. The last supported version for the OrCAD Layout max import was 17.4-2019 Bear in mind that OrCAD Layout was end of life at the end of March 2009, so the 32-bit translator was supported in various guises for around 13 years before being dropped from the 22.1 Release, and onwards.
