  3. Join us on Wednesday June 17, 2026 for a live “Ask Me Anything...
  • Replies 18
  • Subscribers 167
  • Views 3516
Join us on Wednesday June 17, 2026 for a live “Ask Me Anything” Dedicated Expert Session: Constraint Manager
Renu Vibha
Renu Vibha 5 months ago
Got Questions on Constraint Manager?
Want clarity on new features and solving everyday design challenges?
Ask a Cadence expert— LIVE
 Join Us Here
June 17, 2026 | 7:30–8:30 PM IST
Topics:
  • Electrical Constraints
  • Physical & Spacing Constraints
Let’s make this an engaging, insightful, and impactful session together!
Bring your questions. Share your experiences. Be part of the energy
  • Vipulc
    Vipulc 5 months ago +1
    Welcome everyone, and thank you for joining today’s expert session. Please feel free to share your questions at any time—we’re here to assist you.
  • Vipulc
    Vipulc 5 months ago in reply to Electro Node +1
    Constraints follow a hierarchical structure (Design > Net Class > Bus > Net > Pin Pair), where rules defined at lower levels take precedence over those at higher levels. For instance, a rule applied at…
  • Vipulc
    Vipulc 5 months ago in reply to CF202606104231 +1
    Check cross-section accuracy (dielectric, thickness) Verify Analysis Modes enabled Confirm correct pin-pair or Xnet definition Validate Manhattan vs routed length usage
  • Vipulc
    0 Vipulc 5 months ago in reply to Siliconmaster
    • Matched Delay: all pin pairs must match each other within tolerance
    • Relative Delay: all pin pairs must match a specific target after applying delta
    Used for bus-to-clock alignment and timing control
  • EDAHut
    0 EDAHut 5 months ago in reply to CF202606104231
    I am also experiencing a clearance issue where my custom spacing constraints set (cset) is being ignored. Allegro 17.4 is applying a different clearance rule, but I can’t locate where the override is happening . In 17.4 constraint manager interface how can o audit a specific net to see the exact hierarchy of applied rules (global vs class vs region) and find out what is overriding my cset?
  • Vipulc
    0 Vipulc 5 months ago in reply to EDAHut
    Please share a screenshot of the session log or the error/warning message you are encountering.
  • Vipulc
    Check for lock files (.lck) and ensure the design is not open in another session; also re-associate the board file in Capture if needed.
    Review the netrev.lst file for hidden warnings/errors, and verify that the “Update PCB Editor board (Netrev)” option is enabled.
    If the issue persists, generate the netlist manually and perform a File > Import > Logic in Allegro to force the update.
  • EDAHut
    0 EDAHut 5 months ago in reply to Vipulc
    Ok will check and see.
    Is it ok to migrate to 24.1? How is the feedback ?
