  3. Extracting and Assigning User Defined Properties
  • Replies 7
  • Views 19405
archive over 19 years ago
I'm replacing wirebonds in a desgn.  I'm selecting them and getting their basic properties (width, layer, etc...), but these objects also have some user defined properties that I would like to get and assign to the new object that's replacing it.
Could someone help me out with getting the user variables (I have had some luck with properties=Selected_object->prop->?).  It will give me a list, but I need to know how to assign these variables to another object that gets created.
Mark
Originally posted in cdnusers.org by MarkG
    You'll be wanting to use
    [b]axlDBGetProperties[/b]
    as in the following snippet
    proplist=axlDBGetProperties(obj_db)
    ;then to do stuff with wich individual prop/val pair
    foreach(prop proplist
    keyy=symbolToString(car(prop))
    vall = cadr(prop)
    );end-foreach
    HTH,
    Chris Walters
    local Cadence guru
    PS - anyone know of a position for a(nother) Cadence guru?
    Originally posted in cdnusers.org by kerchunk
    Hi Chris,
    Thanks for the code it really helps. I was also wondering if you could show me how to assign these values to a newly created object in the database. If I were to create a new cline, how would I assign the keyy and vall variables to the new cline?
    Mark
        axlDBAddProp
    for assigning a property to an object.
    Grep the SKILL shareware for examples on how to apply the command.
    Good Hunting,
    Chris Walters
    local Cadence guru
    PS - Anyone know of a position for a(nother) Cadence guru?
  • aries
    aries over 17 years ago
    I am reusing your proposed solution in the script below:
    mydbid = axlGetSelSet()
    myprop = axlDBGetProperties(mydbid)
    foreach(prop myprop
    keyy = symbolToString(car(prop))
    val1=cadr(prop)
    );end foreach
    but I am getting this warning:
    "Invalid database id argument - (dbid:181471104)"
    Please advise
  • Randy R
    Randy R over 17 years ago
    The Select Set is normally returned as a list so you need to get the dbid, not a list of dbid(s).  You can process each item using foreach() or car() if you're sure there's only one item.  For example; "mydbid = car(axlGetSelSet())".
