  2. Design Entry HDL
  3. ERROR(SPMHNI-175) IN CREATING THE NETLIST
  • Replies 14
  • Subscribers 27
  • Views 20319
AnirudhTHABJUL
AnirudhTHABJUL over 10 years ago
Hello Everyone,
I am electronic engineer working in Paris.
I am using ORCAD 16.6 for designing our schematics and PCB layout.
In order to design the PCB layout we need to create NETLIST file right.
So, while creating this netlist i have got following error
" ERROR: File "SNB_PSB.brd" is being edited by user "THABJUL" on date "Mon Nov 30 15:20:05 2015" on system "ANIRUDH_THABJUL". Resolve lock file and re-run netrev.
#1 ERROR(SPMHNI-175): Netrev error detected."
Can any body help me in solving this issue?
Anirudh
  • KONAKONDLA
    0 KONAKONDLA over 6 years ago
    #2 Run stopped because errors were detected
    netrev run on Nov 14 11:40:59 2019
    DESIGN NAME : 'NRF52832_BLU_A01A'
    PACKAGING ON Mar 2 2016 00:37:24
    COMPILE 'logic'
    CHECK_PIN_NAMES OFF
    CROSS_REFERENCE OFF
    FEEDBACK OFF
    INCREMENTAL OFF
    INTERFACE_TYPE PHYSICAL
    MAX_ERRORS 500
    MERGE_MINIMUM 5
    NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
    NET_NAME_LENGTH 24
    OVERSIGHTS ON
    REPLACE_CHECK OFF
    SINGLE_NODE_NETS ON
    SPLIT_MINIMUM 0
    SUPPRESS 20
    WARNINGS ON
    2 errors detected
    No oversight detected
    No warning detected
    cpu time 0:00:15
    elapsed time 0:00:00
    INFO(ORCAP-32005): *** Done ***
  • KONAKONDLA
    0 KONAKONDLA over 6 years ago in reply to steve
    COMPILE 'logic'
    CHECK_PIN_NAMES OFF
    CROSS_REFERENCE OFF
    FEEDBACK OFF
    INCREMENTAL OFF
    MAX_ERRORS 500
    MERGE_MINIMUM 5
    NET_NAME_LENGTH 24
    OVERSIGHTS ON
    REPLACE_CHECK OFF
    SINGLE_NODE_NETS ON
    SPLIT_MINIMUM 0
    SUPPRESS 20
    WARNINGS ON
    2 errors detected
    No warning detected
    cpu time 0:00:15
  • steve
    0 steve over 6 years ago in reply to KONAKONDLA
    Check the Session log for the actual errors. Post that up if you are unsure
  • TECHNIQUES
    0 TECHNIQUES over 5 years ago in reply to steve
    Checking Entire Design: Trial_1
    INFO(ORCAP-2212): Check Power Ground Mismatch
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VD3P3_SI
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VCC_ETH_1V1
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? V5P0
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VCC_3V3
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VCCINT_C5
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? GND
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VIO1_FX
    QUESTION(ORCAP-1589): Net has two or more aliases - possible short? VD1P8
    Reporting Unused Refdes in multiple part packages
    Part Quantity Reference
