  3. Add positioning hole to symbol - Allegro/PCB Editor
  • Views 2561
TAyres
TAyres over 12 years ago
Hi all,
I'm creating a footprint for a Camera Link connector (26 pin 3M MDR connector); I need to add some mounting and positioning holes. Should I define them as 'pins' and leave them as unplated drill holes? I'm sure there's a better way.
-Travis
  • TAyres
    It looks like I need an UNSPEC pin, then to define the top copper layer for the lockstand solder pad outline. I'm trying to see how to do that, but have thus far failed.
  • oldmouldy
    oldmouldy over 12 years ago
    Define them as Mechanical Pins in the symbol since these will not be connected in the netlist. Design the Padstacks in the Pad Designer, use rectangular for the "lockposts", plated or non-plated set in the Pad Designer, as required. For the locating pins, just specify a "small" regular pad to locate the drill centre that will be drilled away, leaving just the hole. Place these padstacks in the symbol with Layout>Pins, set the Type to Mechanical, no Pin Number, before placing them.
