  3. Pin name rotate with component
  • Views 17362
Jeri
Jeri over 10 years ago
Hi, I have a newbie question.
Is there a way to set pin numbers to rotate with the component?
Also is there a way to change the text of net names on pads?
  • steve
    steve over 10 years ago
    The pin number text rotates as you rotate the part so not sure what your issue is here. Turn on the layer Package Geometry / Pin Number and you can see the pin number text. For the embedded netname, it's driven by the schematic so if the net is called ADDR3 that's what you will see in the pin and cline (track). If you want to change it open the schematic and change it there, then re-import the netlist.
  • Jeri
    The Package Geometry - Pin number is turn on.  But for me when I rotate a part the pin numbers don't.
    And for the net name I was referring to changing the text size and font not the name.  I have to zoom in very close to read the net names.
  • Jeri
  • steve
    Open the filename.dra and turn on the same layer - what are they set to ? If required use the - edit spin command, set the Find to just text and make sure the Options menu has the origin set to Symbol Origin then window the pin number text, pick an origin point and only the text will rotate around the origin. For the netname size there are no settings for this - you'll just have to zoom in. For both of these options try simply hovering over the pin, you see a tooltip with information on, press the TAB key to cycle through what you see. You can customize the datatip from Setup - Datatip Customization so can get all the info you require without relying on embedded text or pin number layer.
