  3. 17.2 alias shortcuts not working
  • Views 14057
Lock2002
Lock2002 over 8 years ago
I'm trying to use the same alias shortcuts that I was using in 16.6 and a few aren't working.
I had  ~z (ctrl + z) assigned to "rotate", but now it seems to be stuck as "cancel". I'm sure of the env file that I'm using because I can change other things and see the effect.
I don't like right-click. I'd prefer a single key to do this. Not a function key. I'm using those to change my grid setting.
Any ideas?
  • redwire
    redwire over 8 years ago
    In the command window, type "alias" and post up the file it generates.  There should be no issue with assigning a key as you did but it sounds like the alias is not properly assigned.
  • oldmouldy
    oldmouldy over 8 years ago
    The default Windows shortcuts were protected in 17.2, see this post on the topic: https://community.cadence.com/cadence_technology_forums/f/27/t/37234
  • Lock2002
    Thanks! that worked.
