  3. Stream Out Dielectric Vias
  • Views 15073
Dmtor
Dmtor over 6 years ago
I am new to Allegro and trying to create a GDS file representing the conductors in the PCB design. Using the stream out functionality I can get the etch and vias for each conductor layer, but I also need the vias traveling through the dielectric, so I can build a 3D model of the conductor geometry.
If I write a conversion file that maps a GDS layer to each conductor layer's vias I can't separate the vias traveling upwards and downwards into the two adjacent dielectric layers. The vias also do not show up in dielectric layers.
How can I create a GDS stream layer that describes the vias in that dielectric layer?
D
  • CadAce2K
    CadAce2K over 6 years ago
    My engineers read the GDS file(s) into their simulation tool and simply re-gen the via definitions in their tool. I've never been asked to create via structures as you've described. Sorry.
  • Joewi
    Joewi over 6 years ago
    Name your Dielectric layers in the stackup...DE0, DE1.
  • Dmtor
    Dmtor over 6 years ago in reply to Joewi
    I have named them and they appear in the visibility side window, but the vias do not appear in the layout when I select them. For some reason the bottom dielectric layer does show its vias correctly
  • Joewi
    Joewi over 6 years ago in reply to Dmtor
    make sure your padstacks has the dielectric pad defined the same size as the drill.
  • Dmtor
    Thanks, doing this or viewing holes this way https://community.cadence.com/cadence_technology_forums/f/pcb-design/16817/how-do-you-turn-on-the-visibility-of-holes
    is a working solution.
