  3. Gen CAM OHIO Issue
  • Views 14680
Gen CAM OHIO Issue
archive over 17 years ago
On our online tool, I have requested for Gen CAM OHIO, which gives the following error:
Waiting for license manager to respond.
License manager timed out, clearing all licenses.
E- *Error* parseString: argument #1 should be either a string or a symbol (type template = "SS") - nil
E- Can't find window; form.gencamName
The version the tool supports is 15.7, and I am facing the problem on version 16.01 also.
Please suggest me any solution.
With Regards,
Prakash
Originally posted in cdnusers.org by knagap
    OHIO refers to Ohio Design Automation who originally wrote a set of add on userware for Allegro. Having used the OHIO tools on V14.2, I attempted to obtain when my new company purchased V15.7 to generate Gencad. I found that the OHIO tools were purchased by a third party who no longer supported my Gencad output requirements.
    Hth,
    Dave
    Originally posted in cdnusers.org by dschaefer
    Prakash,
    Although we no longer use the Gencad interface, it is still licensed. It requires a Flex license key to run. The OHIO products (including Gencad) were purchased by PTC (ptc.com). If you are/were under maintainance, you should be able to receive support, including a new license key.
    Hope this helps.
    Originally posted in cdnusers.org by cdavies
    I also forget to mention that it does work under version 16.01.
    Charles / Prakash,
    Hmm ... PTC refused my request, possibly because I was requesting to purchase a new license?
    Sounds like it's still available, apologies if my post was misleading.
    (Have 2 e-mails from PTC dated May 2007 informing me that the product has been EOL'd and is no longer supported - guess I'll reply and check if they've changed their position !!)
    Hi Dave/Davies,
    Do you mean to say that conversion for Gen CAM OHIO is not supported from v15.7 or earlier version?
    Can I remove this conversion option from my tool?
    Note: I am not a board engineer to understand these fully, I am trying to interpret the explanation given by you and act accordingly.
    With Regards,
    Prakash
