  2. PSpice
  3. Spark and ignition coil driver simulation
  • State Suggested Answer
  • Answers 1
  • Subscribers 33
  • Views 3252
Kamyk
Kamyk over 1 year ago
Hello. Is it possible to simulate spark jump over two electrodes in PSpice ? I would like to compare a few designs of coil drivers and ignition coils. But I am not sure how to set the "air gap" and ignition coil in Pspice.
Best regards.
  • AyushD
    AyushD over 1 year ago +1 suggested
    As per my understanding you can use a voltage controlled switch to model the behavior of a spart plug. Check below link on how to model a voltage controlled switch in PSpice. https://www.ema-eda.com…
  • AyushD
    0 AyushD over 1 year ago
    https://www.ema-eda.com/how-to-page/how-to-create-a-switch-spice-model/
    Hope it helps.
  • HIMS
    0 HIMS over 1 year ago
    You can try the following:
    For modelling sparks, you can try using exponential burst source, refer link below:
    https://www.ema-eda.com/how-to-page/how-to-simulate-repeated-exponential-electrical-fast-transients-efts/
    For modeling ignition coil, you try modeling magnetic coil - links that can help mentioned below:
    PSpice magnetics.lib
    https://www.flowcad.de/AN/FlowCAD-AN-PSpice-BH-Curve.pdf
    PSpice is shipped with numerous coil models too - refer below - navigate to Categories > Magnetics
    https://www.cadence.com/en_US/home/tools/pcb-design-and-analysis/analog-mixed-signal-simulation/pspice/pspice-models.html?filter=8036
