  2. Sigrity
  3. SI Engineers, This One's for You! - Live Experts Session...
  • Replies 21
  • Subscribers 23
  • Views 1531
SI Engineers, This One's for You! - Live Experts Session on Aug 19th 2026
Renu Vibha
Renu Vibha 2 months ago
Curious about S-Parameters, Insertion Loss, or Return Loss?
Bring your questions and join our upcoming Cadence Sigrity SI/PI Live Experts Session.
Learn proven analysis techniques, hear practical use cases, and interact directly with Cadence specialists.
Topic - Pre-layout Simulations covering Aurora Workflows, Topology Workbench (Pre-layout), Power SI ERC
Participate here  on August 19th at 7:30-8:30PM IST.
Bring your questions. Leave with answers
  • AK20250609765
    AK20250609765 1 month ago in reply to EDAHut +1
    Thank you for the question. To maintain the validity of pre-layout signal integrity (SI) results when the PCB stackup changes during the design cycle, follow these steps: Correctly Model Devices: Ensure…
  • AK20250609765
    0 AK20250609765 1 month ago in reply to CF202606104231
    AI servers and high-performance computing (HPC) systems introduce several unique challenges for signal integrity (SI) engineers:
    1. Heterogeneous Architectures: The integration of various processing units, such as CPUs, GPUs, and AI processors, requires careful management of signal integrity across different components, which can complicate design and validation processes.
    2. High-Speed Signaling: The demand for high-speed data transfer increases the risk of signal integrity issues, including crosstalk, attenuation, and reflections. Engineers must implement advanced techniques to mitigate these effects.
    3. Memory Bandwidth Limitations: The "memory wall" phenomenon, where memory bandwidth does not scale with the number of cores, poses challenges in ensuring that data can be efficiently accessed and processed without bottlenecks.
    4. Thermal Management: Increased power consumption from high-performance components generates heat, which can affect signal integrity. Engineers must design effective cooling solutions to maintain optimal operating conditions.
    5. Electromagnetic Interference (EMI): The complexity of modern AI workloads can lead to increased EMI, necessitating careful design to minimize interference and ensure compliance with regulatory standards.
    6. Complex Routing Constraints: The intricate layouts required for high-speed signals on PCBs can lead to routing challenges, requiring innovative design strategies to maintain signal integrity.
    7. Modular Designs: The shift towards disaggregated architectures and modular designs, facilitated by standards like UCIe, requires SI engineers to adapt to new connectivity standards and ensure compatibility across diverse components.
    Addressing these challenges is crucial for the successful deployment of AI servers and HPC systems, ensuring reliable performance and efficiency in demanding environments.
  • EDAHut
    0 EDAHut 1 month ago in reply to EDAHut
    During pre layout engineer creates a tuned LPDDR4 memory topology with specific termination resistors using generic schematic nodes … when transferring this to physical layout , mismatching pin names between the schematic symbols and the actual layout footprints break the net connectivity mapping in Aurora .. this completely resets the constraint manager rules, forcing the layout team to manually reassign routing constraints from scratch
  • CF202606104231
    0 CF202606104231 1 month ago
    When a channel fails compliance testing , what SI  metrics is typically investigated?
  • AK20250609765
    0 AK20250609765 1 month ago in reply to EDAHut
    The handoff typically breaks down when the logical connectivity used during topology creation no longer matches the physical implementation. Pin-name mismatches, component-definition differences, or connectivity mapping issues can prevent correct constraint transfer, forcing manual re-assignment of routing constraints in the layout flow. Maintaining consistent schematic-to-layout mapping is key.
  • AK20250609765
    Thank you for the question. When a channel fails compliance testing, engineers typically investigate insertion loss, return loss, crosstalk, ISI, eye margin, and SNR. The goal is to determine whether the failure is caused by excessive channel attenuation, reflections from impedance discontinuities, coupling from aggressor nets, or degraded receiver margin. In practice, S21 (insertion loss), S11 (return loss), crosstalk, eye opening, and SNR are among the most important indicators used to isolate the root cause of a compliance failure.
