  3. how to pass array of parameters through CDF down to a verilogA...
  • Replies 11
  • Subscribers 127
  • Views 22701
how to pass array of parameters through CDF down to a verilogA code?
naderi
naderi over 13 years ago
 Hello all,
 Is there any way to pass an array of parameters down to a verilogA code?
if I put following statement in a verilogA sub-circuit.
parameter real vdc[3:0] ={0,0,1,0};
Then {0, 0, 1, 0} appears in CDF parameters for vdc. However, spectre complains later during circuit read-in.The error message is :
 Error found by spectre during circuit read-in.
    ERROR (SFE-874): "input.scs" 1087: Unexpected block statement "{".
I realized if I enter the parameters within double-qoute as "{0, 0, 1, 0}" at CDF, then spectre will be happy and goes for simulation, but the results are incorrect.
I wonder if there is any solution?
Ali
    Ali,
    Make the value in the CDF "[0 0 1 0]". It needs to be netlisted with spectre's vector syntax, rather than the VerilogA vector syntax.
    I just tried this, and it works fine.
  • naderi
    Thanks for reply.
    Here is my verilogA code. When I enter "[0 0 1 0]" (as you sugessted) spectre complains about the missing comma between values.
    Giving  "[0, 0, 1, 0]" passes the compiler and then transient simulation shows wrong values for the output voltages as [ 589.3E6,  9.223E-297, 0.0, 0.0] .
    I tried it on IC6.1.4-64b.500.9 ,"v2009.4_23.21"
    Ali
    `include "constants.vams"
    `include "disciplines.vams"
    `define LENGTH 4
    module vbus(A);
    output [`LENGTH-1:0] A;
    voltage [`LENGTH-1:0] A;
    parameter real vdc[`LENGTH-1:0] =[0, 0, 0, 0];
    analog
    begin
            generate i (`LENGTH-1,0)
            begin
                    V(A[i]) <+ vdc[i] ;
            end
    end
    endmodule
    Ali,
    You misunderstood. The VerilogA code needs to use {0,0,1,0} syntax, but in the CDF you'll need to define the default as [0 0 1 0] (no commas, although commas are tolerated at the moment - but you get a warning about them not being supported in the future). Also, when you instantiate the block, with a different value, you'd need to specify it with square brackets. To illustrate what I mean, here's some VerilogA:
    module blah (op,ip);
    output op;
    input ip;
    electrical op,ip;
    parameter real vdc[3:0]={0,0,1,0};
    analog begin
       V(op) <+ vdc[2]*V(ip);
    end
    endmodule
    and here's the corresponding spectre netlist:
    I1 (o1 i1) blah vdc=[2 2 2 2]
    v1 (i1 0) vsource type=sine freq=1M ampl=1
    ahdl_include "blah.va"
    tran tran stop=2u
  • naderi
     Awesome, Worked just fine.
    Ali
  • kawan
    kawan over 11 years ago
     Andrew,
    I ran into the same problem and I tried out your solution. It did not work and I wonder if the solution is now different with cadence 6.1.5 ?
     // VerilogA for zakir_sim1, bb_prereg_ldo, veriloga
    module trim3bits(sel);
    output [2:0] sel;
    electrical [2:0] sel;
    parameter real trim[2:0] ={0,0,0};
    analog begin
    V(sel[2]) <+ trim[2]*1.1;
    V(sel[1]) <+ trim[1]*1.1;
    V(sel[0]) <+ trim[0]*1.1;
    end
    endmodule p, li { white-space: pre-wrap; }
    Begin Incremental Netlisting Oct 8 16:44:23 2013
    "ERROR (OSSHNL-524): Netlisting failed as function hnlNetNameOnTerm was called with a non-existent terminal name on current instance 'I6' in design 'zakir_sim1/test1/schematic'. Ensure that argument to this function is a valid terminal name and netlist again.\n\n"
    End netlisting Oct 8 16:44:23 2013
    ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
    ...unsuccessful.
    That looks as if there's a mismatch between the pins on the symbol and the pins on the veriloga view. Or there's something wrong with the CDF.
  • Narasimhan90
    Narasimhan90 over 10 years ago
    The above solution works when we actually pass parameters since the default parameters {1,2,3,4} are overridden by the passed parameters [1 2 3 4]. Generally I do not override parameters if I want to use the defaults. But due to this syntax problem I have to always pass parameters for the simulation to work.
    Is there a fix planed(to sync syntax of veriloga with spectre or viceversa)?
    Thanks and have a Wonderful day,
    Narasimhan Rajagopal
    Narasimhan,
    There's not a need for spectre and veriloga to be aligned in terms of syntax, but there is a CCR for this to be handled correctly in the CDF - CCR 1094193. However, there is no plan to fix this - maybe that would change if more people asked for this via customer support.
  • SimhanAnalog
    SimhanAnalog over 9 years ago
    Thanks Andrew. I will notify this to our EDA team. They will take it up with Cadence support on a priority basis.
    Narasimhan
  • nouning
    nouning over 6 years ago in reply to Andrew Beckett
    hi Andrew, I am facing the same issue: "ERROR (SFE-874): "input.scs" 1087: Unexpected block statement "{"." Has this issue been resolved yet? Can Spectre now handle VerilogA arrays such as {1,2,3,4}. Thank you.
