  3. Virtuoso Video Diary: Comparing Multiple Tests and Sharing…
Yuan Li
Yuan Li
Analog Design Environment
ICADVM18.1
ADE
simulator options
IC6.1.8
Assembler
ADE Assembler
Virtuoso Video Diary: Comparing Multiple Tests and Sharing Settings
21 May 2019 • 4 minute read
Today's blog highlights the features of the new Multi-Test Editor that is now available in ADE Assembler. With this blog, we have come to the end of the mini blog series that covered a lot of interesting, just-released features in Virtuoso®ADE Assembler, Virtuoso®ADE Explorer, Virtuoso®ADE Verifier, and Virtuoso® Visualization and Analysis. We hope you found these blogs useful. Click here to see what other topics we covered in this series.
Have you been in a situation where you wanted to change a particular simulation setting in multiple tests in Virtuoso® ADE Assembler? This can be a tedious process because you have to figure out which tests have that setting, and then make the changes in each test one by one.
In IC6.1.8 ISR3 and ICADVM18.1 ISR3, we have added a tool called Multi-Test Editor to do just that for you.
Using this tool, you can compare and selectively copy simulation settings across all or some specific tests. While doing this, you can also review the simulator defaults shown in the same interface. I bet you'll agree that this will be a great time saver and a good medium for sanity checks.
Comparing Multi-Test Settings
For an easy comparison of simulation settings and their values, you can do the following in Multi-Test Editor:
  • Choose a reference test with which you want to compare the other tests.
  • Use column filters to focus only on specific simulation settings or values.
  • View the simulator defaults for each setting.
  • Identify the deviations in the compared values from the colored visual cues.
  • Opt to view only those values that are different.
  • Select the type of settings to be compared. For example, you can select only environment options and analyses settings.
Sharing Test Settings
Another key feature of Multi-Test Editor is the ease of copying and sharing settings. While the comparison is in progress, you can choose to copy values for a particular setting or a complete category of settings (node) from the reference test to all or specific other tests. You do not need to open the test setup individually to make any changes. Just make the changes and click Save. The active setup in ADE Assembler reflects all the changes.
Similarly, if you have modified the active setup while Multi-Test Editor is open, you can refresh the editor to synchronize the values.
 To know more about Multi-Test Editor and its features, check out the Using Multi-Test Editor in Virtuoso ADE Assembler video available on the Cadence Support portal.
Video
  • Using Multi-Test Editor in Virtuoso ADE Assembler
User Guide
ADE Mini Blog Series
  • Virtuoso Video Diary: Creating and Previewing Stimuli
  • Virtuosity: Filtering Plots!
  • Virtuoso Video Diary: What's New in Reliability Setup
  • Virtuosity: The Top 3 Post-Layout Enhancements in Analog Design Environment
  • Virtuosity: Did My Checks Pass or Did They Not Run?
  • Virtuoso Video Diary: The Next Big Thing — ADE Verifier Teams Up with Cadence vManager
For more information on Cadence circuit design products and services, visit www.cadence.com
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the Cadence Online Support Video Library. Hundreds of interesting videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on regular basis. Click Subscribe to visit the Subscriptions box at the top of the page in which you can submit your e-mail address to receive notifications about our latest Virtuoso Video Diary posts.
Happy Reading!
Yuan Li
