  3. LVS error concerning multiplicity of transistors + IBM ...
  • Replies 15
  • Subscribers 130
  • Views 22999
LVS error concerning multiplicity of transistors + IBM cms9flp
jimito13
jimito13 over 15 years ago
Hello everyone,
I came up with the following LVS error concerning all transistors with multiplicity factor m (NOT with just fingers and no multiplicity factor in contrary) in my design.LVS debug environment details give the following description :
FET1comp has mismatched parameter(s):"w" layout: 1.5e-05 schematic: 7.5e-06
Let me be more specific.For the above description,in my design i have a transistor with Wtotal=15um and multiplicity factor m=2 (thus 2 fets in parallel with 7.5um width each),well,assura can make the correct computation for the layout and it shows the actual Wtotal but it cannot estimate the correct value for the Wtotal for the side of the schematic (it seems considering m=1 always independent from the value i have set in the fet properties).Is there any way to get rid of this error (with some switch under Modify avParameters menu for example) or i should make any change to the compare rules file to the respective funtion?I show you the properties of the nfet :
Width Single Finger : 7.5u
Width All Fingers :7.5u
Fingers :1
Multiplicity :2
Thus,Wtotal=15u as i mentioned earlier.
The following lines contain the part of the compare.vldb file with the respective section for the FET1comp function :
procedure( FET1comp(m1, m2)
let((paraminfolist )
paraminfolist='(
("l" "abs_comp" "if(BentGate<0.5 then hgp else hgp7)")
("w" "abs_comp" "if(BentGate<0.5 then hgp else hgp7)")
unless(getValCase(m1 "m") m1->m=1)
unless(getValCase(m2 "m") m2->m=1)
unless(getValCase(m1 "idg") m1->idg=0)
unless(getValCase(m2 "idg") m2->idg=0)
if( (m1->idg && abs_comp(m1->idg 0 0.5)) then
m1->w = getValCase(m1 "w") * getValCase(m1 "m") )
if( (m2->idg && abs_comp(m2->idg 0 0.5)) then
m2->w = getValCase(m2 "w") * getValCase(m2 "m") )
unless(getValCase(m1 "bentgate") m1->bentgate=0)
unless(getValCase(m2 "bentgate") m2->bentgate=0)
BentGate = m1->bentgate + m2->bentgate
genericcomp("FET1comp" m1 m2 paraminfolist)
I must say that i use IBM cms9flp pdk finally if somebody didn't notice that on the post subject.Also Cadence IC 6.1.3 under opensuse 11.1 operating system 64-bit.
Can somebody give me a helpful hint how to solve this problem?Changing all transistor to bus will be a painful procedure for me and i want to avoid it if possible.
Thanks in advance for any helpful answer and if more clues are needed ask me to post them here.
  • Quek
    Quek over 15 years ago
    Hi jimito
    This indeed seems like a small bug in the compare rules. IBM pdks have long compare rules file and so I think ultimately you might have to request for more support from your local IBM or Cadence support centre.
    Would you please check the cdf info for the cell to see if the multiplicity property is really "m" or some other name (e.g. mfac, mf, etc)?
    In ciw, go to "Tools->CDF->Edit CDF".
    Quek
  • jimito13
     I checked the menu you suggested but i didn't find any information...
  • Quek
    Hi jimito
    Suppose the multiplicity problem is for a schematic cell named "nfet123" in library "myTechLib". Would you please help to execute the following cmd in ciw and upload the output file "cell.cdf"? Please use the upload function, not cut and paste.
    cdfDump("myTechLib" "cell.cdf" ?cellName "nfet123" ?level 'base)
    Please also provide the following info:
    terminal>assura -W
    terminal>virtuoso -W
    Please also upload the "design.vlr" file in the lvs run directory.
    Quek
  • jimito13
     Hello Quek,
     At first thanks for your interest to my problem.I run the command in ciw but the cell.cdf output file is empty(!),so there is no reason to upload.What can we see from this file if it had something in it?
     The file with .vlr extension is IBM confidential and i can't post it or upload it anywhere...Guide me with a similar file that apparently you have as well and i will give you the feedback for the thing that we must know from that file.
     Output from the 2 commands in terminal :
     IC6.1.3.500.13
    3.2_USR2_HF11
    Regards
  • Quek
    Hi jimito
    I am trying to find out the actual cdf parameter name for the "multiplicity" parameter in the properties form. Not very sure why your cdfDump is empty. : )  Would you please help to do the following?
    a. In the ciw (this is the first window that shows up when Virtuoso starts up), go to "Tools->CDF->Edit CDF"
    b. Use the "Browse" button and select the transistor that has the problem.
    c. The cdf form shows up
    d. In the top right hand corner, enter a filename and press the "CDF dump"
    Hopefully the gui will be able to help you generate a proper file. Please upload the file.
    Quek
  • jimito13
    Quek,
    I did the procedure you mentioned above but at first i am not given the ability from the gui to choose the transistor that has the problem but i can choose the schematic or layout view,so doing this the cell.cdf file has some parameters with "nil".Doing what you suggested for a single nfet of the cms9flp library,the actual cdf parameter name for the "multiplicity" parameter is "m".What is exactly the CDF??
     And a final and a little bit irrelevant question with the above.Virtuoso makes sometimes a sound like a beep.I know how to shut it down,but i want to do it permanently...Do you know a command that i can write in a file (is this file .cdsinit?) to do it?
     Thanks in advance.
  • tkhan
    tkhan over 15 years ago
    I do this in .cdsenv, but you can easily change the syntax if you want it to be in .cdsinit:
    ui beepVolume int -100
  • Quek
    Hi jimito
    CDF refers to Component Description Format. It contains the parameter that your instances has and controls which parameters go into the netlist. Since "multiplicity" does indeed has parameter name "m", it is not a matter of indentifying a custom mfactor name to Assura. It would be quite tough to debug without a testcase so it would be good if you can contact your local Cadence/IBM support for this problem.
    Best regards
    Quek
  • jimito13
    Hello Quek,
    Thank you very much for your effort to help me with this problem.This is the last step,to contact my IBM representative...Hope they have a solution.
    Best Regards,
    Jimito13
  • jimito13
     Well,i contacted IBM and the first answer was this :
    "In layout, if the pcell has multiplicity parameter set to >1, then there will be a layer called MULTI DEV surrounds the pcell. This will prevent the LVS from combining devices in the layout"
     I replied to them saying that i can't find that layer anywhere and asked them to guide me to find it and the final anwer was this :
    "It appears that in cms9flp Assura VLDB mode LVS does have some problems recognizing multiplicity from the schematic side. Assura CDL mode and Calibre LVS will both recognize multiplicity properly. I will investigate further on the Assura VLDB mode LVS. Please use CDL mode LVS or Calibre LVS if you can"
    The problem is the following,trying to use CDL the error vanishes but others concerning devices and nets come up that don't make sense since my testcase is one nfet so if there was such an error it could be visible easily.Other problem is that we don't have calibre and the time to learn how to use it until the tape-out that is in a few days!
    Finally i decided that i must change to bus mode naming for the transistors and the problem is solved partially since some nets get strange name like net33<0> and i can't even check n' save my schematic...
    I am in desperate condition,please if somebody knows a way to get rid of this damn problem,let him do it,i will appreciate it.
    Thanks in advance.
